We're winning the case!
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 01-12-2007, 01:43 PM
Rebel Racing 3's Avatar
Rebel Racing 3 Rebel Racing 3 is offline
1997 Chevy Truck 1500 5.7 Wont Start
We have a 1997 chevy truck that will not start unless we poor gas directly into the intake....We have replaced the fuel put distrubitor...Cam sensor. And the code we are getting off of it is p1345 any ideas would help Thanks in advance
Old 01-12-2007, 03:31 PM
LiftFlat LiftFlat is offline
Would seem the injectors are not firing...verify fuel pressure first...thats too new for me to have a clue on the codes though.
Old 01-12-2007, 03:52 PM
DeathRattle's Avatar
DeathRattle DeathRattle is offline
Some Punk Kid
http://check-engine-light-codes.blo...-p1345-and.html
http://forums.pickuptruck.com/showf...500&Main=295223
^^Those trucks still run with that code^^. So I would say your initial problem is no fuel. If you have the tool do a fuel pressure test at the valve on the fuel rail. If you dont have tool and just want to see if you have fuel at the rail just depress the valve with a small screwdriver. Wrap a shop towel around the screwdriver. Otherwise if fuel is there with pressure it could spray somewhere you dont want it to.
Old 01-12-2007, 04:01 PM
Hogg Hogg is offline
Here is the code info:
P1345
SGC (Cam Position) Sensor Circuit Malfunction/ Crankshaft Position - Camshaft Position Correlation
You cam and crank sensor correlation is out of whack. The PCM needs to know EXACTLY the position of the crankshaft in relation to the camshaft in order to detect misfires and other functions. Whenever you change in a new part that can effect this relation, you need to "introduce" the new part to the PCM.
You need to have either a GM dealership perform a CASE relearn. (crankshaft angle sensor error)
What parts did you replace??
I caught the cam sensor(its in the distributer), but what fuel part did you replace?
Anytime you replace a cam , crank sensor, engine blaock, or crankshaft or PCM you need to have this CASE relearn performed. This is also known as a Crank Relearn.
The Tech. will hook up the scan tool to the OBD2 port, he will insert some of your VIN digits into the scan tool, and then follow its directions. This takes about 2 minutes to do.
Try and find a smaller garage to do this as they usually dont charge as much. Some places will do it for free, do you have a friend at a garage??
Also make sure the fuel pump is working, do you hear it run as you turn teh key to crank the engine over? Fuel pressure should be at 58-66 key on engine off.
Could be a fuel pump, or fuel pump relay that is located in the fuse panel under the hood.
Post back. I also have a 1997 Vortec 350 truck.
peace
Hog
NorthStar NorthStar is offline
If pressure drops to about 45 psi injectors wont squirt fuel. Would check fuel pressure. The P1345 code means that distributor is not aligned properly in relation to crank signal, need to put #1 piston back at tdc compression and check rotor alignment. Careful! Dont break plastic housing when installing cap holddown screws.
Old 01-13-2007, 10:37 AM
Ok this is where it gets confusing, Ok when i unscrew the bleeder and plug a fuel pressure gauge in and cycle the key itreads between 20-50 psi, but the fuel but is a brand new one from carquest, also if i leave the key on the presure will go too 100
Old 01-13-2007, 11:03 AM
100psi!!! Thats too high.
Is the return line blocked off?
Or are you somehow dead heading the supply line?
If return is open and fuel is being supplied to fuel manifold & regulator then I would say you have problem with gage or regulator not working.
Theres probably an internal relief valve inside fuel pump to keep it from building super amount of pressure that could cause line to blow or something. So that has to be why you are getting 100psi.
Old 01-14-2007, 08:38 PM
100psi is way too much. It sounds like the pump is deadheading somewhere.
The fuel pressure rgulator is located inside the intake manifold.
Is the return line clear?
peace
Hog
Old 01-15-2007, 12:09 PM
We undid the return line and left the pressure side in, turned the key off and nothing came out of the return line is this normal
Old 01-15-2007, 02:06 PM
With how much pressure on supply side? If its 100psi no thats not normal.
If theres a problem with regulator might be good time to install entire new assembly fuel manifold, regulator, injectors everything. Theres an update part number 93441235 that you can buy. Rather than mess around with individual components. High mileage engine, its about ready to start nickel & diming you with something else failing.
Old 01-16-2007, 11:13 PM
Pics of the newer injection setup
http://www.pacific-audio.com/perfor...ges/231640.html
I would do that as well.
Post #9 of this post shows the new and old spider injector setup(old 1 being on top)
http://www.performancetrucks.net/fo...ad.php?t=356743
peace
Hog
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "1997 Chevy Truck 1500 5.7 Wont Start"
New owner 58 chevy truck Lee Hester Introduce Yourself 5 10-29-2006 03:45 PM
Car 235ci into '53 Chevy Truck New2theart Engine 8 10-17-2006 12:37 AM
looking for a pic - the Navarro (?) families 68/69 chevy truck lowROLLERchevy Hotrodders' Lounge 0 10-03-2006 03:24 AM
86 chevy won't start 56Thunder Engine 15 08-19-2004 03:11 PM
69 chevy truck front end change dragn azz Suspension - Brakes - Steering 4 07-23-2003 01:16 AM
