1997 Suburban 4x4, 4l60e no reverse, imagine that. - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 10-18-2009, 09:49 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I did not mention 2 stages , I said 2 sections on the low - reverse piston.
That piston has 2 sections on it. Three O-rings create 2 sections for fluid apply. The reverse section is larger than the low gear section.
  #17 (permalink)
Old 11-02-2009, 07:48 AM
finally got the transmission back in yesterday. While it was out I replaced the leaking rear main seal and oil pan gasket. Everything seems good so far with the trans. Pressures check out OK, much better than with the "problem" trans.
I want to thank all of you that helped with my questions along the way. This is a great site and I'm glad I stumbled upon it.....lots of knowledge shared here.
In the near future, assuming nothing comes up with my rebuilding of this thing, I might put in Transgos 4l60e-hdc-2 kit. Any opinions of that kit? The old 'burb isn't a hotrod, but I'd like to feel comfortable if I hook onto a load to pull, a motorcycle trailer or at the heaviest an open car trailer with my son's drag truck. (93 S-10)
Thanks again Crosley and bunch.
4l60e 4x4 problem. Loud Clicking!! 327amc Transmission - Rearend 28 02-23-2012 10:09 PM
86 Dodge 4x4 727 tranny no reverse after loud metallic pop sound? mike 96 ws6 Transmission - Rearend 4 03-14-2006 11:43 AM
4L60E 4x4 tarmon8r Transmission - Rearend 0 03-10-2006 07:47 PM
99 tahoe 4X4 - lost overdrive & reverse tank2323 Transmission - Rearend 1 12-27-2002 04:20 PM
77 Suburban K-20 4x4 roof skins 01SSCamero Body - Exterior 2 12-10-2002 09:30 AM
