Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1998 4L60E stuck in second gear
Old 05-14-2009, 09:07 PM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
Originally Posted by dlevi2121
I have a 1998 s-10 Blazer that wont shift out of second gear the codes bring up a shift solionid I changed both of them on that did not fix it I still have park,neutral,reverse but anly one forward gear it takes off it second and stays there it dont slip and the fluid looks great any ideas?
Did you clear the codes?
How many miles on the trans?
stuck in 2nd gear can be more than solenoids.
Any fuses blown ?
Speed-O working properly?
