1998 Chev 4l60e shift troubles - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-09-2011, 10:56 PM
I have a 4l60e in a 1998 chev. I recently changed out the tranny with a used one. The factory tranny started to slip when accelerating up a hill when it kicks down. It also slipped when kicking down to pass. The used tranny i put in has the exact same symptoms. I reused the wiring and tcc selenoid from the original transmission. What could my issue be??????
Old 01-10-2011, 05:38 PM
mine slipped the same.it kept blowing the fuse under the hood. but the overdrive clutch was gone as well.
1996 chev 4x4 truck with 4L60E Shift problems plumbright Transmission - Rearend 6 10-14-2010 08:53 AM
4L60E shift troubles litewaite Transmission - Rearend 1 04-27-2010 08:11 PM
1998 4L60E stuck in second gear dlevi2121 Transmission - Rearend 4 05-15-2009 06:27 PM
1998 chevy half ton with 4l60e.. rsmall2 Transmission - Rearend 2 12-29-2008 09:13 PM
4L60E Troubles mpturner Transmission - Rearend 3 09-02-2008 03:25 PM
