1998 dodge stratus engine replacement - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-20-2009, 06:48 PM
SonnyFaust's Avatar
does anyone know if the engine has to come out the bottom or can it come out through the top on my 1998 dodge stratus before i get started any help is greatly appreciated.
Old 01-20-2009, 07:42 PM
i just did a 2000 intrepid with the 2.7, out the bottom was easy.
sam-missle
Old 01-20-2009, 08:35 PM
Wiki Edits: 31
my experience with FWD is, it is easiest if you remove the cradle from the bottom.. that gives you good access to everything, as the engine, trans and lower 1/2 of the suspension is attached to it
Old 01-20-2009, 08:38 PM
SonnyFaust's Avatar
its a 2.0 and every where i call they tell me somethin different the dodge dealer ship told me they thout it could come out the top a junk yard told me the bottom
Old 01-20-2009, 08:46 PM
Wiki Edits: 31
pull the struts off the control arms, cut your fuel line ( and plug it ).. disconnect the rack and drop the cradle.. the engine can easilly come out the top of the cradle with plenty of room to work..
setting points on sb chevy frackster66 Electrical 23 01-07-2014 06:50 PM
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 07:57 PM
2002 Dodge Stratus R/T P0301 redlightning Engine 2 06-02-2007 12:18 AM
Dodge van engine swap Lonestar Engine 3 07-21-2006 09:05 AM
engine compartment panel replacement 67stang Body - Exterior 3 01-20-2003 06:01 AM
