1998 Firebird Control arm bushing replacement - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-17-2014, 04:28 PM
hi everyone . Iam working on a 1998 firebird . I need to see if anyone no how to change the upper and lower control arm bushing ?
Old 03-17-2014, 04:37 PM
techinspector1's Avatar
Wiki Edits: 326
You need a FACTORY SERVICE MANUAL.
1998 Camaro Firebird and Trans Am Repair Shop Manual Original 3 Volume Set
Old 03-17-2014, 05:49 PM
Banned
Sure do, take apart. Press out the old & press in the new & Reinstall.
The Following User Says Thank You to killeratrod For This Useful Post:
techinspector1 (03-17-2014)
Old 03-17-2014, 06:28 PM
Wiki Edits: 326
Sounds like one of those fosdick Haynes or Chilton manuals hahahahahaha.
1. Disassemble
2. Re-assemble in reverse
No problem.
The Following User Says Thank You to techinspector1 For This Useful Post:
glensz28 (03-19-2014)
Old 03-17-2014, 06:35 PM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
I know how.
actually, they should be struts, not control arms,IIRC
Fact is stranger than Fiction
The Following User Says Thank You to LATECH For This Useful Post:
Old 03-17-2014, 06:40 PM
LATECH's Avatar
Hmmm.They have both. Lookslike overkill to me.
Looks like You have to remove the brake caliper,spindle, then the lower control arm,then the upper control arm
Control Arm Bushing Predator4 Suspension - Brakes - Steering 8 01-18-2013 12:04 PM
Control Arm Bushing replacement- Keep existing shells fasteddy51 Suspension - Brakes - Steering 3 07-12-2011 11:42 AM
1968 GTO upper control Arm bushing replacement adam83 Suspension - Brakes - Steering 6 12-20-2010 01:00 PM
upper control arm bushing helrazr3 Suspension - Brakes - Steering 9 05-23-2007 09:58 PM
Control Arm bushing replacement bonuts Suspension - Brakes - Steering 7 03-14-2005 08:06 AM
