1998 Ford Explorer woes - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-27-2009, 06:39 PM
Mr.Fixxit's Avatar
I know this is probably the wrong forum site for a post like this, but please just help me out. Buddy of mine has a 1998 Ford Explorer Sport, 4 - wheel drive. For some reason it will not disengauge the 4 wheel drive. It has the automatic Torque on demand system. And, that is what i believe could be holding the transfer case in 4 WD, and not allowing it to go into 2 WD.
Old 12-27-2009, 07:17 PM
cucumber1949's Avatar
T-Bucket, Corvette, Mustang
The Ford Explorer enthusiast forum has a ton of information and posts on the transfer case. The following copy/paste (including the misspellings) from that forum describes two things to look for before getting your hands really dirty:
T-CASE DISENGAGEMENT
On a 4x4 system, especially those equipped with eletric shift (like 2nd-3rd Gens), the system may not disengage when the vehicle has been driven on a dry surface. The variation in the rates of tire rotation results in transfer case loading and binding. When this occurs, the pressure is too great for the electric shift motor to overcome. To confirm, place the vehicle on a lift, allowing the wheels to rotate freely. This relieves the pressure on the transfer case. If the transfer case will now shift properly, it confirms transfer case loading. The first check should involved a tire circumfrence measurement from front to rear. Often we encounter this condition folllowing the installation of the spare tire.
There is an enormous amount of info on that forum including how to remove and rebuild the case. I have a 97 Explorer that had the range slider and fork failure that I drove for 12,000 miles after the first symptom. Finally pulled the transfer case and rebuilt it myself with parts from a guy who deals in transfer case / transmission parts out in Seattle. Total cost $120 and it runs like new. Was not that hard to do as I followed the rebuild instructions from the forum.
Old 12-28-2009, 10:28 AM
Rexnfx's Avatar
Make sure all tires are same manufacture, same size, worn the same amount and same air pressure. If one is different, you can get all kinds of problems on AWD or auto 4WD vehicles.
Wanna Talk Cars "Fords" 66Falcon Hotrodders' Lounge 17 10-01-2005 05:29 AM
early 90s Ford Explorer rear ends poncho62 Transmission - Rearend 5 04-20-2005 08:43 PM
91 v6 ford explorer timing off druid Engine 1 03-04-2005 06:14 AM
1998 Ford Mustang GT Convertible Rearend MustangMojo Transmission - Rearend 0 02-26-2005 08:52 PM
70's Era Ford F150 Explorer paint HELP!! godofgsxr Body - Exterior 5 12-23-2002 05:00 AM
