1998 Ford Taurus will not start up - Page 4 - Hot Rod Forum : Hotrodders Bulletin Board
  #46 (permalink)
Old 01-04-2011, 04:18 PM
i have gotten it to run. the guy i had messing with the starter had both wires attached to the starter. once i had him look at my 94 he knew what he did wrong on the 93. after we got it runnin it blew alot of white smoke.. there was whitesmokin comin from the valve covers too i think. after thaty finally settled down the car did briefly over head. after gas was put on it tho i think the coolant was released.
  #47 (permalink)
Old 01-21-2011, 02:33 AM
after driving the car for a little over a mile i can not get the car to go over 1mph.. it will not go in any gear, its bumping, sometimes if it sets it will get power back and run but its not at this moment. this car is a 1993 and i also want to know if a diagnostic can be hooked up to it at autozone. it does run intermittently but its now just not moving enough to make an incline. the tranny, torque converter, fuel injectors, etc have been risen as possible culprits but we do not know.
  #48 (permalink)
Old 01-21-2011, 06:41 AM
poncho62's Avatar
Wiki Edits: 5
Sounds like you have a blown head gasket (white smoke)
  #49 (permalink)
Old 01-22-2011, 10:22 AM
the white smoke has long gone. its normal grey now.
  #50 (permalink)
Old 01-22-2011, 03:00 PM
LATECH's Avatar
So its out of coolant and now its burning all the oil out of it. Next the engine will seize up. Might take it out now while the torque converter bolts are easier to get to.
Black smoke = unburned fuel
white smoke = spent coolant passing through the engine or exhaust
blue or grey smoke= oil consumption
No smoke = normal combustion
no smoke = engine not running
yours is heading south. Sorry
  #51 (permalink)
Old 01-23-2011, 02:42 AM
its not a lot of smoke at all really. coolant isnt leaking and the oil has stayed at the same level really. its just this bizarre acceleration issue and this horrible timing with the turn signals and the break lights which some how corrected themselves..
  #52 (permalink)
Old 01-23-2011, 05:55 AM
LATECH's Avatar
So then your saying the coolant is full, and the oil level is ok?
  #53 (permalink)
Old 01-23-2011, 12:53 PM
T-bucket23's Avatar
Wiki Edits: 26
if there has been a lot of smoke from the exhaust, you may have a clogged cat. It will kill power and some cars will die or not run above idle
Chet
  #54 (permalink)
Old 01-23-2011, 04:59 PM
YOU ARE WASTING YOUR TIME TRYING TO GET IT HOOKED TO OBD2 DIAGNOSITICS....
Sorry for shouting, If it runs do the basics,
Change your plugs, wires,. Post the 8th digit of the Vin and the 10th. If its a U its a 3.0LT pushrod engine, not that bad of a motor. Pour in a can of GM, BG or Techron Fuel system cleaner. Clean the Throttle body with spray and a Tooth brush or rag.
Fire up car. If it is running smooth and not bucking and jerking when it looses power its probably a Transmission (its a FORD not hating just stating)
Common issues on the 3.0 motors 96-99
1. Cam Sensor Failed (bird chirping at idle in center of motor)
2. DPFE (ECL EGR Flow Excessive) Aluminum Factory sensors corode and quit working 10 minutes and back side of engine.
3. Intake and Head gaskets (not really common but occasional)
4. Dirty injectors,
5. Bad Power Steering
6. Bad Steering racks leak mostly on Drivers side.
7. Transmissions
8 Motor mounts.
These are things I see pretty frequently the top 2 are the most common problems I see. I will say that I have gotten several in with well over 200K with zero major problems. Heads, Trans, Engine failure. Good Luck
With LAtech get a real Mechanic to Eye it over whether in a shop or off his clock.
  #55 (permalink)
Old 01-23-2011, 05:45 PM
Forgot a few,
Ball joints, Tie Rods, and Stabilizier links are common.
Forgot why its a waste to get the ECL checked.
The basic scanners will tell you a code IE (Po301, 302 or PO 300 Cyl mifs fires or random misfires) if its running rough it may or may not tell you why. There isn't a Code for weak fuel pump, shorted ignition. Failing crank sensor (some models). And if it has a misfire, it will only further the need to check plugs, wires, spark quality.
Best bet check the basics. There isn't a code that tells you to do a tune up directly, nor one that tells you a fuel pump is failing.
Also Idle could still be the IAC valve, they have a very high fail rating usually cause surging idle, extended cold start idle problems, and stalling when warm. If you keep a foot on the throttle all the time it will usually stay running.
  #56 (permalink)
Old 01-23-2011, 05:48 PM
POST THE VIN PLEASE we need to get an accurate make and model year. If its a 93 stay away. If its a 3.8 especially. Head gaskets are so bad on those cars its not funny. i grew up in Michigan my family owns Ronda Tire, and we paid our Childrens Childrens Children college funds with Head Gaskets on 3.8s and Transmissions.
  #57 (permalink)
Old 01-23-2011, 06:01 PM
LATECH's Avatar
I grew up in big rapids i have heard of ronda tire, that was in GR wasnt it?
  #58 (permalink)
Old 01-23-2011, 11:06 PM
we already figured that out man..
1falp5342pa102396 i dont know why you keep saying 3.0 when i said it was a 3.8..
im going to try to run this old raggity gas out 1st things first and put some fresh stuff in, then look at that gas filter.
not hating just stating? i like that lol i do. but i am a dodge man so hate away, i'll probably join you lol
dont own that, i own a '93 which i guess i should try to correct the thread title.. All this raggin on trannys and head gaskets on '93 3.8s is alarming me.. you have any consumer reports or recalls to back what your saying?
  #59 (permalink)
Old 01-24-2011, 04:14 AM
LATECH- Yes its in GR I grew up just North or there. If I hasdn't met my wife in Lynchburg VA I would be back there probably assisting in managing a store.
1 to remember here is the list of engine TSB (Tech. Service Bulletins from Alldata)
Title
02-21-13 10/28/2002 Engine - Cylinder Head Straightedge Surface Check
02-11-4 06/10/2002 Aluminum Engine - New Cleaners/Service Tips
02-2-3 02/04/2002 Engine - Aluminum Block/Head Machining
02-1-4 01/21/2002 Engine Head Gasket - Approved Replacement Procedures
02-1-9 01/21/2002 Engine Oil - Oil Recommendations/Applications
99-8-16 05/03/1999 Motor Oil - Viscosity Grade Recommendation
98-23-10 11/23/1998 Engine - Lean Driveability Symptoms
98-7-4 04/13/1998 Engine - New Gasket Sealer
98-4-9 03/02/1998 Cooling System - Coolant Loss And/Or Overheating
9675 03/25/1996 Engine - Intermittent Hesitation/No Start/Stalling
95243 12/04/1995 Engine - Rocker Arm Squeak/Chirp/Knock Noise
92M77 06/01/1995 Campaign - Early Deterioration Of Engine Mounts
94B48 06/01/1994 Campaign - Fuel Tank Contamination
941010 05/18/1994 Lower Intake Bolt/Stud - Revised Torque Procedure
94109 05/18/1994 Engine - Rocker Arm Squeak/Chirp/Knock
93253 12/08/1993 A/C and Accessory Drive Belt - Breakage/Squeal
932314 11/10/1993 Engine Gasket Surface - Cleaning Procedures
93237 11/10/1993 Engine - Lack of Power/Hesitation/Stumble/Stalls
9397 04/28/1993 Flexible Fuel Vehicle - Engine Oil Specifications
Auto Trans Issues
06-14-4 07/24/2006 A/T - Mercon V ATF Usage
03-14-8 07/21/2003 A/T - Cooler Flushing Service Tips
02-17-6 09/02/2002 A/T - Inadvertent Shift Interlock Disabling
99-15-2 07/26/1999 A/T - Transmission Flush and Fill Tool Available
98-13-12 07/06/1998 A/T - Flushing Oil Cooler And Lines
98-3-8 02/16/1998 A/T - AX4S/AX4N New Transaxle Fluid
97-23-7 11/10/1997 A/T - AX4S/AX4N Codes Stored After Replacement
962612 12/16/1996 Torque Converter - Cleaning and Replacement Guidelines
96249 11/18/1996 A/T Torque Converter - Leak Test Procedure
961714 08/12/1996 A/T - AX4S New Main Control Cover and Pan Gasket
9687 04/08/1996 A/T - AX4S/AX4N Driveline Noises
96511 02/26/1996 A/T - Revised GROB Spline Drive Joint
ATRATB368 01/01/1996 A/T - Case Breakage at Rear Planet Support Snap-Ring
ATRATB360 01/01/1996 A/T - AX4S (AXODE) Rear Sun Gear Bearing
ATRATB359 01/01/1996 A/T - AXOD, AX4S (AXODE) Revised Forward Sprag Race
95177 08/28/1995 Transaxle Clutch - Clearance Revision
951610 08/14/1995 A/T - New Rotunda Fluid Changer Service Tip
95157 07/31/1995 A/T - Revised Torque Converter Identification Codes
95314 02/13/1995 A/T - AXODE/AXOD New Design Filter Service Tip
95312 02/13/1995 A/T - AX4S/AX4N TSS Sensor Air Gap Measurements Change
ATRATB314 01/01/1995 A/T - Delayed Engagement, Shift Errors, MLPS Codes
ATRATB310 01/01/1995 A/T - TCC Pulsing On/Off, High Line Pressure, No Codes
ATRATB308 01/01/1995 A/T - AXODE Erratic or High Line Pressure
ATRATB294 01/01/1995 A/T - Drive Axle and Wheel Lug Nut Torque Specifications
ATRATB278 01/01/1995 A/T - AXOD/E Accumulator Springs Identification
ATRATB267 01/01/1995 A/T - Delayed or No Forward/Reverse, Shifts Out of Gear
94247 11/28/1994 A/T -AXOD/AXODE/AX4S Gear Engagement Concern
94215 10/19/1994 A/T - AX4S/AXOD New Lube Tubes
94208 10/05/1994 A/T - AXOD/AXODE/AX4S Retaining Ring Orientation
94209 10/05/1994 A/T - AXODE/AX4S No Gear Engagement/Noise
94145 07/13/1994 A/T - AXODE Transmission Exchange Program
9467 03/23/1994 A/T - AXOD/AXODE/AX4S Leak At Torque Converter
ATRATB251 01/01/1994 A/T - AXOD/E Erratic Shifts
ATRATB225 01/01/1994 A/T - Forward Sprag Upgrade
ATRATB204 01/01/1994 A/T - Modification to Improve Gear Lubrication
ATRATB191 10/01/1993 A/T - Failsafe Modes
93165 08/04/1993 A/T - AX4S/AXODE Redesigned Rear Lube Tube
93164 08/04/1993 A/T - AXODE Shift Indicator Indicates Incorrect Gear
93135 06/23/1993 Engine - Won't Crank/Start
ATRATB169 06/01/1993 A/T - AXOD/E Electrical Diagnostic Information
9226A11 12/16/1992 A/T - AXODE/AXOD Revised Turbine Shaft Seal Ring
ATRATB151 12/01/1992 A/T - AXODE Uncontrollable Lock Up
92207 09/23/1992 A/T - AXODE Air test Plate Modification
ATRATB132 09/01/1992 A/T - Intermittent Electrical Problems
92188 08/26/1992 A/T - AXODE Do Not Service Tag Instuctions
ATRATB101 03/01/1992 A/T - AXOD/E No Forward or Slips in Forward Gears
ATRATB099 02/01/1992 A/T - AXOD/E 44T4's and 125's Chain Stretch
ATRATB078 11/01/1991 A/T - How To Use A Pressure Gauge
ATRATB028 10/01/1990 A/T - Engine Vacuum Testing
ATRATB9002006 02/01/1990 A/T - Choosing the Right ATF
ATRATB8930 10/01/1989 A/T - Math Part II
ATRATB8927 09/01/1989 A/T - Twenty Steps To Successful Repairs
ATRATB8923 08/01/1989 A/T - Math Formulas Part I
ATRATB8754 09/01/1987 A/T - Front Bushing Wear
ATRATB8748 08/01/1987 A/T - Slipping or No-Shift/Metal Sealing Rings
Hope that tells you a bit of the history. The Heads bill out at 12.7 Hours basic build. After you've done 2-3 its a 6 - 7 hour job tops. Like I said they paid my way through college.
I can't see the point in putting 100-300 dollars and several hours work into a car that has been
A. sitting for 2 yrs.
B. Is known to have issues.
C. Is worth more in scrap Steel than running
Unless it has under 75K miles. and is really nice shape.
I do this for a living, (I work for a repair and sales dealership (not New car)) so I have a large amount of knowledge in these. If I saw it on craigslist I wouln't even call unless the mileage was low. try to find a Camry or corolla as a cheap project they are simple design easy to work on and very long lasting Usually.
  #60 (permalink)
Old 01-24-2011, 04:17 AM
Just thought of something, Since it runs,
GO to Advance Auto parts, borrow there coolant pressure tester, (loan a Tool 175 bucks)
start engine with it hooked up (read instructions) pressurize to 15LBS while running if white smoke ensues, hook to a tow truck and bring to your local crusher steel was at .10 on the 100. White smoke under pressure will indicate heads
1997 ford taurus help randy28384 Electrical 3 11-11-2010 08:14 AM
'91 Ford 300-6 won't start every time techinspector1 Engine 5 08-08-2008 02:26 PM
1998 Ford F-150/1957 Ford Delivery Sedan Dennis Anderson Introduce Yourself 1 12-29-2006 06:10 PM
Trying to help sister with her 95 Ford Taurus 406chevelle Engine 31 01-21-2005 11:41 PM
1996 ford taurus mychevystang Suspension - Brakes - Steering 1 10-19-2004 01:46 PM
