1998 ford vin U vulcan question - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-09-2010, 01:46 PM
fast68's Avatar
likes chevy trucks & boobies
ok got a timin chain job to do on a 98 sable/taurus 3.0L vin U Vulcan
these are single cam right?
the specs just say OHV
well that doesnt help much...
no chit its an overhead valve engine duh...
if its DOHC then im not touching it..
also can you leave the water pump on the timing cover or are there timing cover attachin bolts hidden beneath the pump?
looks like another big "fun" job..
just got the 96 caravan 3.0L crank seal job done this morning and wow you gotta literally remove every single bolt and part off the engine block to remove the timing belt set and oil pump to replace that front seal.. omg wow....
hours upon hours of wrenching,
all for a 6 dollar seal...
thanks
Old 03-09-2010, 02:53 PM
Valkyrie5.7's Avatar
www.generationhighoutput. com
Last wiki edit: Painting chrome wheels
Last journal entry: Stopping my journal entries here
Wiki Edits: 15
The Vulcan and Essex motors were all OHV, which means that they are in-the-block single cams (with exception to the SHO's DOHC Vulcan-based V6). The Duratec motors are the head-cammers.
Old 03-22-2010, 06:27 PM
fast68's Avatar
ok thanks
still i dont think they are named correctly
but hmm.
ended up not doin this job
there was nothing wrong with the chain set in it
he was misinformed about them needing to be replced in these engines
they never need it done.
Old 03-22-2010, 06:39 PM
Wiki Edits: 31
people mistake them for the 4.0L SOHC engines ( Ford Ranger used both engines ).. SOHC engines is sometimes easier to swap in a good engine than replace a timing chain as they use 2 of them, and usually get ' timing chain rattle ' by 60k miles
List all of your cars HERE! Carbed95GT Hotrodders' Lounge 289 11-09-2011 06:43 PM
1998 Ford F-150/1957 Ford Delivery Sedan Dennis Anderson Introduce Yourself 1 12-29-2006 06:10 PM
32 Ford, 39 Ford tailight question. deere Hotrodding Basics 3 11-05-2006 07:00 PM
Ford Y-block Question onetwin69 Engine 3 10-24-2006 05:21 PM
vin number on a 33/34 ford acourtjester Engine 5 09-19-2006 08:13 PM
