1998 gm z-71 5.7 - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-21-2013, 03:58 AM
1998 gm z-71 5.7
I just installed a new set of plug wires, Cap & Roter. Soon after that a problem started for no reason the truck started to skip a beat almost like the engine cut out for a nano second? I pulled the dist. and installed a new gear and the problem went away for a few hundred miles then started back up. Then I installed a new fuel pump & Filter of which the problem again went away for a day now while driving down the road it happens about every 30 seconds? I have owned the truck since new and have always kepted it well maintained. any ideas? I also replaced the Dist. pick up plug.
Old 03-21-2013, 01:03 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
plug
I,m guessing that you may have a cracked spark plug that is causing the intermittant missfire.
Old 03-21-2013, 01:50 PM
1998 gm Z-71 5.7
Not the spark pluges, today it ran fine all morning then just an hour ago it started to buck again? I know what a bad plug will do.
Old 03-21-2013, 03:33 PM
EOD Guy's Avatar
Put the out cap back on and see if it goes away...... I had more than one bad NEW cap, seems like there is a hair line crack in them and it'll misfire when it gets hot etc..... but not all the time...... return the cap and put on a new one, problem went away
1998 silverado differential sonnyfresh@sbcglobal Transmission - Rearend 1 08-14-2011 12:18 PM
1998 s10 jumm Engine 5 08-27-2010 01:35 PM
1998 3.8 v6 turbo sk8fate Engine 3 07-18-2009 07:52 PM
1998 Camaro help. sk8fate Engine 5 06-28-2009 06:43 PM
1998 yukon doeboy Introduce Yourself 1 07-29-2007 04:31 PM
