1998 jeep cherokee - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-09-2006, 04:32 PM
1998 jeep cherokee
I have a 1998 jeep grand cherokee 6 cylinder when i drive it the vehicle constanly cuts out what is the problem with it....
Old 12-09-2006, 08:37 PM
Jmark's Avatar
Ummmmm, let me look into my crystal ball wrench......Ah!!! I see the problem!!!! It's broke!!! My suggestion.......take it to a shop and have them find the problem!!
Old 12-10-2006, 02:31 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Yeah... waaaaay more information needed. That's like going to a doctor and saying, "my foot hurts, what's wrong?" You gotta say, "my foot hurts when I walk on the outside of it after I sing the national anthem."
Old 12-11-2006, 08:44 AM
farna's Avatar
Last wiki edit: AMC V-8s Last photo:
Wiki Edits: 14
Well, I can tell you about a few common problems with the 4.0L six.
1) Check the CPS (crankshaft position sensor) connector. Get come contact cleaner, pull the connector, spray it, then put it back. If there is no CPS signal the thing won't even run. An intermittent or waek signal can produce problems.
2) Check the ignition module connector -- same as above. This is the more likely culprit! I think the coil sits on top of the ignition module (mine's an 87 model). Pull the coil and clean the contacts between the coil and module.
3) The coil is mounted on the engine in the later Jeeps. If yours is, think seriously about relocating it. The engine heat and vibration isn't good for the coil -- more than one has failed on off roader vehicles. They move it for better reliability. If the coil is starting to fail you have to replace it.
If the problem is from the start, I'd suspect the CPS or ignition module connector. If it's only when the engine is warmed up, the coil is probably going bad. But these are just guesses from previous experience. A more detailed description of when the cut-out occurs will help.
Jeep XJ (cherokee) abuse ChevelleSS_LS6 Hotrodders' Lounge 1 07-16-2006 08:30 AM
1998 Jeep Grand Cherokee Jeeper 4-Ever Transmission - Rearend 3 06-20-2006 07:59 PM
340 Chrysler into Jeep Cherokee Lonestar Engine 2 05-30-2006 04:59 AM
95 jeep cherokee distributer cap replacement? 72 chevy elcamino Engine 1 06-05-2005 06:09 AM
'01 Jeep G. Cherokee Fan & Temp Lights Tekmanic Interior 5 12-15-2004 10:46 PM
