1998 s10 crank sensor
I have removed the small bolt holding in the crank position sensor in my s 10 pickup and when I pulled on the end of the sensor to remove it the plug end broke off. now what I have is the rest of the sensor broke off in the block flush. Any suggestions on how to remove the rest of the sensor?
OOps I forgot to tell yall the motor that I am dealing with is a 2.2 four cyl. any help you can give would be appreciated I am considering trying to drill a hole in the center of the sensor and threading in a screw to try and pry it out with.
I still need help!
PB Blaster or something similar may help. As mentioned above, maybe you can screw something into it and pull it. It is usually very helpful to twist them a bit before attempting removal. Sometime the plastic cases get brittle due to the heat, it makes them susceptible to breaking. If it is accessible you could try drilling a small hole in it and thread in a self tapping screw. I personally think heat is going to case you more problems and would save it for a last resort.
Artificial Intelligence is no match for Natural Stupidity Chet |
| S10 to '49 Olds? | grouch | Suspension - Brakes - Steering | 100 | 10-22-2010 03:57 PM |
| 41 chevy on s10 frame- wheelbase issues | lumberjacknooj | Body - Exterior | 18 | 01-18-2009 04:48 AM |
| V8 Beetle on S10 blazer chassis??? | zbhover | Hotrodding Basics | 2 | 10-25-2008 02:09 PM |
| Ford Flathead Chevy S10 Transmission Swap | tommy98466 | Transmission - Rearend | 4 | 08-01-2008 06:38 AM |
| S10 pickup or S10 Blazer frame? | raj4851 | Hotrodding Basics | 10 | 01-06-2006 09:28 PM |
