1998 silverado differential - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-14-2011, 11:59 AM
how do you remove the pinion gear from the rear end of the 1998 Silverado
Old 08-14-2011, 12:18 PM
The drive pinion, which is the gear splined to the flange that the driveshaft connects to, comes out of the housing through the rear after removing the diff. Remove the pinion nut and use a big hammer and a brass drift to drive the threaded pinion stem out of the front bearing. Most are not extremely tight.
Silverado differential cover size cutsupreme Transmission - Rearend 20 05-15-2011 08:58 AM
1998 Rear Differential Tag numbers noyes_nci@msn.com Transmission - Rearend 1 03-25-2011 02:39 PM
1998 s10 jumm Engine 5 08-27-2010 01:35 PM
1998 Silverado rear end questions Maalakai Transmission - Rearend 10 06-21-2010 11:18 AM
1998 Camaro differential parts swapout thomaseh Transmission - Rearend 2 09-28-2009 03:34 AM
