Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1998 Vortec 355 parts build Questions
Old 09-03-2011, 09:42 AM
Steveon91 Steveon91 is offline
First off this is for a small 18ft boat, I didn't build the motor and there is no warranty. This should be about a 320 hp max rpm 4800 engine
I need to fix #1 spun rod bearing that happened shortly after startup . I believe about an hour of time on the motor on the Water. I would assume the rod and crank Journal are bad. The Crank rod Journal is at .20 already So
Should I buy a new Scat STD Crank for 189.00.
Eagle brand is 20 dollars cheaper but heard scat was better
Use a good STD 305 crankshaft I have sitting here and have it checked and Polished and balanced for the 350 pistons for 225.00
I was going to purchase Clevite p series mains and rods for this application.
