Originally Posted by ssmonty
I personally have a Scat 9000 crank for a 383 in the works, and every journal measured good as far as being concentric and no taper. I haven't checked the stroke yet, but from what I've seen so far I don't expect any surprises. I haven't got the rotating assy. balanced yet either, but if it needs balancing work thats not Scats fault because I didn't get the pistons from them.
I bought the Scat after doing a lot of research and getting various recommendations as well as hearing a lot of negative things about others.
FWIW
PS The Scat is steel where the 305 is cast iron.
Hey my Friend,
Sounds like the Scat Crank is the way to go!
