Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1998 z28 4l60e problems
Old 01-12-2011, 05:11 PM
transbuilderguy transbuilderguy is offline
if the shift solenoid was bad you wouldnt have third also since that same shift solenoid for 2nd is off in third also unless for some weird reason solenoid B is staying on you may need to look at scan tool data and see what gear is being commanded. possible sticking 2-3 shift valve, were the feed holes to the shift solenoids drilled if they were drilled to big more than .030 it can cause a no 2-3 until outrageous speed as it floods the shift solenoids and keeps the valve stroked when it should be exhausting. these are 2 issue there are more also maybe a bad 3-2 downshift solenoid bad
