1999 2 door 2.2 Cavalier auto to 5 speed swap what do I need - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-02-2010, 12:41 AM
Hi, I have a 2 door cavalier 2.2L 1999 that Im converting from automatic to 5 speed. Does anyone know what all i would have to do to make the computer happy? Its stalling every time I shift. Still has automatic computer. I think the 5 speed is the same anyway. Computer reprogram needed?
Old 09-02-2010, 09:40 AM
The computers are transmission specific. You may be able to get yours reflashed.
Old 09-02-2010, 01:15 PM
so I take it thats most likely the problem then. I tried putting a 5 speed computer in but wouldnt run for long because of the theft thing killing it. Swapped ignition switch stuff but still had theft light. not sure 5 speed computer one was the exact year
Old 09-07-2010, 12:35 PM
Not sure I want to reflash if it wont solve the between shifts issue. Not even sure what I would tell a dealer if I took it there, or would they know what to do.
Old 11-30-2010, 11:46 PM
Just go to a local scrap yard and get your self a 98-99 5 Speed computer. Or get a Gm reflash. Automatic and standard use the same computer but with diferant files on them. If you do decide to get a used computer make sure to disconect the batterie before changing the computer other wise u will turn on anti-theft.
Th350 to 4 speed auto conversion Bandit1980 Transmission - Rearend 3 12-29-2004 07:41 PM
swap a TH350 for a four speed? bildo95 Transmission - Rearend 3 02-02-2003 06:43 PM
converting from 5 speed to older auto. Badbowtie21 Transmission - Rearend 1 01-31-2003 02:48 PM
66 283 auto / 67 283 swap Question FasterPastor Engine 1 11-05-2002 12:48 PM
235 Engine / Powerglide to 3 speed swap New2theart Engine 2 07-16-2002 06:22 PM
