I have the same vortec in my truck right now and you don't have to take your timing cover off the motor to get it running if your not using any electronics and just running a hei distributor. The vortec 350 has a plastic timing cover. On mine there is a spot of what looks like its for the crank sensor for the timing on whatever vehicle it came out of. But its not hooked up and does not need to be taken off to run. I am running a hei and the same carb your using and it runs fine. Post some more info on what your using for ignition wise.
Eric |
If your plastic timing cover still has the sensor in place, you can leave it- otherwise you will need to plug the hole. If you do not have a sensor in the cover, then you also do not have the ring on the crank- but either way it does not matter to the engine whether or not the ring is there. It will run the exact same way, with or w/o the ring. |
| Vortec heads on 76 chevy 350 | chevy_c10 | Engine | 7 | 03-18-2009 12:32 AM |
| 1999 Surburban Vortec 350 need build help | RICHat22 | Engine | 3 | 02-08-2009 04:28 PM |
| 96 chevy 305 vortec heads on 350 block | badriand | Engine | 6 | 02-20-2006 07:45 AM |
| Chevy Vortec 350 Truck question | 79 Malibu327 | Engine | 3 | 07-08-2004 10:41 PM |
| Chevy 350 Vortec Heads | graybeard42 | Engine | 8 | 05-27-2003 01:34 AM |
