1999 eldorado with engine problems. Swap ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-13-2013, 06:17 PM
i have a beautiful 1999 eldorado of course it has the head bolt issue i found a 2010 deville with 20000 miles will the engine fit in my 1999 eldorado if not what model yrs northstar will fit the 1999 eldorado?
Old 05-15-2013, 12:53 PM
No, that 10 4.6 will NOT work. Your options are very limited, IIRC only a 98 or 99 will fit your car.
I had a 98 that had the headgasket issue. I got a guy to install head studs that he designed and installs. He did it all for $1100 installed, including pulling the engine.
I had an STS Seville with the 300hp engine, the SLS got the 275hp engine which has differnt cams.
His name is Jake, and he runs Northstar Performance. Search that title.
peace
Hog
Vortec Engine Swap Problems 5700 350 capps Engine 22 01-28-2016 12:06 AM
1999 SHO transmission problems fdxman1215 Transmission - Rearend 5 02-27-2012 11:04 AM
1999 suburban 4l60e problems saltybob Transmission - Rearend 6 09-28-2007 09:53 PM
im having wiring problems with an engine swap ntx_gearhead Electrical 6 03-06-2007 10:53 PM
1985 Cadillac Eldorado Problems!?!? fireforsin Engine 6 04-19-2004 04:24 PM
