1999 Ford taurus wagon, brake pedal sensor........ - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-03-2007, 07:23 AM
My in laws Taurus has a problem with the brake pedal sensor. When they push the brake to shift to or out of park, it will sometimes give them a hard time. I got in and checked position of the sensor this morning, shifted through the gears a minute, and got back under the dash to check it out. I had no problems with it, exept the sensor got really warm, almost too warm. Should that sensor get hot?
Old 09-03-2007, 10:33 AM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
need to add
That would a brake light switch.
Thought I had a pic of it somewhere (I do---just can't find it just yet)
If that thing goes out--chances are you have no brake lights.
I just went thru this on my 97 T-bird
To get around this when it completely fails>>>>
Turn the key just past the "lock" poition-----before the run position
Put car in "Neutral"
Start car.
Get that fixed ASAP-----No brake lights are not a good thing.
Bryan
(EDIT)
Also check for a broken wire near the switch connector (my experience)
Old 09-04-2007, 03:34 PM
1999 Taurus
The Taurus also has a "Shift Lock Actuator" connected to the bottom of the steering column. It receives a signal from the brake light switch through a red wire with a light green tracer. There are 2 other wires on the actuator, one gray with a yellow tracer from fuse #5 in the fuse panel under the dash, and a black ground wire. If that's getting hot you probably need an actuator. On the other hand, usually electrical devices, the switch or the actuator, get too hot because there is too much current flowing through them. Did someone replace a 10 amp fuse that kept blowing with a 30 amp fuse? In any case, I agree with the previous reply and get it fixed asap before you have a fire under the dash.
Old 09-04-2007, 06:49 PM
There is a Ford recall on this exact problem. Take it to a dealer and get it fixed for free.
Paul
Excessive brake pedal travel......... Trans Am Tony Suspension - Brakes - Steering 10 05-13-2007 07:07 PM
Where is the ETC Sensor on a 2.4l ford RodFather Engine 3 01-21-2007 05:18 PM
1999 Ford Taurus 3.0 Freeze Plug Leak - Help leejoy Engine 27 12-25-2006 06:22 PM
94 to 95 Ford Taurus engine and trans swap 406chevelle Engine 6 11-20-2005 02:14 PM
Whatever happend to these guys? hot_rod_kid Hotrodders' Lounge 20 12-17-2002 09:20 AM
