1999 olds alero 2.4 not running on all cylinders. - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-24-2008, 04:52 PM
Hello, I am working on a 1999 olds alero with the 2.4L in it (quad 4 engine). It doesnt run on all 4 cylinders. Ive never worked on one of these engines before. Im not even sure how to tell which cylinders are not firing or if the cause is fuel or fire. I pulled the plugs and they all look light tan. So none of the plugs are black or have signs of not firing, so that doesnt help. No check engine light noted. autozone or advanced auto can test the ignition modules but I dont know how much stock I would put in that. The car has 83,000 miles on it. I checked to see it has coolant in it and it does have the dex cool red crap in it. Tail pipe finger test produced typicial black soot on the finger. Im not sure what a blown head gasket would look like on plugs with dex cool coolant.
Old 08-24-2008, 08:35 PM
I dont think I can check for spark, unless there is an unknown way to do it that I havnt heard of. Is it possable to lift off the ignition module/coil pack cover and connect everything up, with a ground strap to the cover?
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 11:00 PM
1991 olds will not stay running 68novafan Engine 4 12-11-2006 08:30 PM
1994 olds 88 running problems. Chopper64 Electrical 7 03-23-2006 05:30 PM
Olds 350 help, 2 dead cylinders & cam lift Q? 360Camaro Engine 35 07-10-2005 03:42 PM
Why is my truck running on a few cylinders? ViperMonster800 Engine 9 04-28-2005 08:32 AM
