Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1999 Pontiac Bonneville
Old 03-12-2012, 01:58 PM
shundaf1 shundaf1 is offline
Originally Posted by T-bucket23
The ground block in the channel under the carpet by the drivers door is a huge problem in those. It looks like a big black plastic connector with a cap on it. They are usually green with corrosion. You need to remove the drivers side front door sill and pull back the carpet to find it
Thanks,I was having problems with my carpet being wet on the rear driver side like it rain in the car even at times that it haven't rain in a few days. So maybe that's the problem
