Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1999 Pontiac Bonneville
Old 01-23-2013, 08:55 PM
hcompton hcompton is offline
Old & Furious
Check the voltage at the bettery when cold and not running and when its running. Should be over 13 when running and around 12 when not running.
Also check the belt and idle pulley it is the water pump and alt belt in one. If its bad or the alt is going badit can be locking up and heating up the system.
