Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1999 pontiac bonneville fire is not getting to fuel injectors
Old 04-18-2012, 09:32 PM
vicrod's Avatar
vicrod vicrod is offline
life is a ride
Last journal entry: 2014
scan tool
The computer needs to scanned for trouble codes with a OBDII tool.
The injectors are controlled (pulsed) by the PCM (computer).
Some troubles will prevent the engine from starting due to wrong or missing input signals, such as "crankshaft position".
So the non firing injectors may be a symptom of another problem.
vicrod
