Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1999 pontiac bonneville fire is not getting to fuel injectors
Old 04-19-2012, 10:45 AM
alittle1 alittle1 is offline
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
When you checked fuses, did you check the main power fuses that are under the hood?
Make sure that you have a healthy battery and even still, connect a battery charger up to it also.
Does this engine 'CRANK'?
Go to this link: http://www.2carpros.com/questions/19...iac-bonneville
http://troubleshootmyvehicle.com/gm_...p_sensor_2.php
http://troubleshootmyvehicle.com/gm_...id_light_1.php
