1999 SHO transmission problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-25-2012, 03:39 PM
I have a 1999 Taurus SHO with a bad transmission, does anyone know if I need to swap out with another SHO or are there other model/years that I can use. The cheapest rebuild I can find is $2400.
Old 02-25-2012, 08:15 PM
Wiki Edits: 85
If you have a manual transmission, you have no choice as no other transmission will fit. And $2400 sounds cheap to me. Last SHO manual CORE that I sold (7 years ago) went for $1200 with an exploded differential through the case.
Old 02-26-2012, 05:12 AM
pricesgarages's Avatar
i didnt think any v8 sho had a manual you will probly have to use a sho tranny 2400 is about the going rate on a rebuild a jasper unit is almost 3000
Old 02-26-2012, 11:31 AM
Wiki Edits: 85
Turns out that no Taurus in 1999 had a manual transmission
1999 Ford Taurus
Transmission
A.T., 6-183 (3.0L), DOHC (VIN S), (AX4N), col shift, ID XF1P-DA
A.T., 6-183 (3.0L), DOHC (VIN S), (AX4N), col shift, ID XF1P-DB
A.T., 6-183 (3.0L), DOHC (VIN S), (AX4N), floor shift, OD cancel switch
A.T., 6-183 (3.0L), DOHC (VIN S), (AX4N), floor shift, w/o OD cancel switch
A.T., 6-183 (3.0L), OHV (VIN U, 1 or 2), AX4N (code X), col shift
A.T., 6-183 (3.0L), OHV (VIN U, 1 or 2), AX4N (code X), floor shift
A.T., 6-183 (3.0L), OHV (VIN U, 1 or 2), AXODE/AX4S (code T or L), (col shift)
A.T., 8 cyl (3.4L, SHO, AX4N), OD cancel switch
A.T., 8 cyl (3.4L, SHO, AX4N), w/o OD cancel switch
The OP should have specified what he had so no one waste band width and time giving him the wrong information.
Most likely the OP will need to use a SHO AX4N as the V8 bell housing is probably different than the non-SHO V6 bell.
Old 02-26-2012, 03:34 PM
tnsmith10's Avatar
when will it rain???
in the last 20+ years, i have never seen a taurus with a manual trans. im sure they exist, i just havent seen one.
as far as the automatic cases go, the duratec 3.0 DOHC might be the same as the SHO. they both have the starter in the same location and the bolt pattern is the same.
Old 02-27-2012, 12:04 PM
Valkyrie5.7's Avatar
www.generationhighoutput. com
Last wiki edit: Painting chrome wheels
Last journal entry: Stopping my journal entries here
Wiki Edits: 15
I'm not surprised, they're hard to come by.
The only Taurus' (Taurii?? lol) with manuals were the 4 cylinder first gen models and the 3.0L Yamaha V6 SHOs. All 3.2L v6 SHOs and 3.4L v8 SHOs came with autos, as did every other pedestrian Taurus. I owned a Manual SHO Taurus and it came with a very rubbery Mazda 5spd trans... I think the same ones the Probe and Mx-6 got. I'm pretty sure Brian has a 5spd SHO as well.
1999 chevy 454 ignition problems "desperate" gconcialdi Engine 4 09-14-2011 07:06 PM
1999 chevy silverado 1500 4L60E transmission problems 4L60E help Transmission - Rearend 0 08-26-2011 11:18 PM
1999 suburban 4l60e problems saltybob Transmission - Rearend 6 09-28-2007 10:53 PM
1999 Chevy Silverado Transfer Case/Transmission? officialfoxracer21 Transmission - Rearend 2 12-15-2002 05:56 PM
Transmission problems kemo Transmission - Rearend 2 11-21-2002 02:48 PM
