Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1999 Silverado Evap Code
  #17 (permalink)
Old 07-18-2008, 12:39 PM
sbchevfreak's Avatar
sbchevfreak sbchevfreak is offline
Licenced Automotive Technician
P0440 EVAP System No Flow During Purge
Does the MIL go off after you fill the tank, and then come back on after you drop below 1/2 a tank? If so, your code is caused by a filter on the evap purge pump. In '99 up to '03-4 trucks, they put these on the frame right where they could collect mud and road grime, ect. When they plug, the evap pump cannot draw in fresh air, upsetting the pressure in the system, and sets P0440. The pump kicks on after the fuel level drops below 1/2 a tank. Unfortunatley, in '99 you cant remove the darn thing to clean it, and it used to cost around $300 for the filter relocation kit.
