1k primer over bare metal????? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-07-2010, 08:18 AM
hi there everyone my name is mike and im looking for some help.i am currently restoring my 78 hz holden kingswood and am planning on taking it down to bare metal.the paint i will be using is ppg dulon midnight black and will be cleared.my question is...can i use the dulon 1k primer/filler over the bare metal?.directions on the back of the tin says its primer and can be used as a primer filler.cheers,mike.
Old 05-07-2010, 08:39 AM
shine's Avatar
SPI Thug
Last journal entry: some progress
no ! 1k is useless over bare metal. unless you are doing a complete lacquer job there is no place for it period. and lacquer does not mean clear coat. it is a type of paint no longer used here.
Old 05-07-2010, 09:04 AM
"the paint i will be using is ppg dulon midnight black and will be cleared"
just google 'ppg dulon paint', I don't think that is what you want to use after that much work, it's not their premium line of paint.
"i am currently restoring my 78 hz holden kingswood and am planning on taking it down to bare metal."
Why? nothing sticks like factory primer.
"can i use the dulon 1k primer/filler over the bare metal?."
Yes you can BUT only if you wish to re-do the job every year. It's your time.
I would really suggest moving up to any 2K system from start to finish.
Old 05-07-2010, 09:16 AM
deadbodyman's Avatar
Wiki Edits: 11
It IS cheaper but it'll cost you in the long run...we used that stuff many years ago but we used etching primer first for better adhesion..I'd use an epoxy primer after stripping...its not That expensive and will last much longer...you'll be a lot happier...most of us do our bodywork on top of the epoxy...
Old 05-07-2010, 09:23 AM
Irelands child's Avatar
I have to believe that you really don't want to re-do your work - ever until you want to do a new color. Pleeeeze - do it with current materials. Yes it will add some NZ dollars now, but at least you will only do it once. Epoxy primer - a good name brand - whatever is available in NZ. Here, most of us like the SPI, but the DuPont or Nason will work well, both are tough as nails and aren't a sanding primer. The PPG - do a search here and you will find that it isn't liked by most.
Dave W
Irelands child
Old 05-07-2010, 09:38 AM
Wiki Edits: 11
IC raised a good point.....get an epoxy that you can sand.....
Old 05-07-2010, 05:43 PM
thank you all for your help.it seems you were all RIGHT!!!!.i guess deep down inside somewhere i was hoping you were all going to say yup use ppg dulon great paint,great price, awesome! but cheap paint=crap paint right?.so i have decided to go with house of kolor.have used their products for hobby airbrushing and seems pretty good.they have EPOXY PRIMER too.quite expensive paint but i really dont want to do the job twice... ever! paint strippig isnt exactly my favourite thing and im sure you will all agree lol.thanks again for your help.
Vertical Welding JohnBrayan Hotrodding Basics 12 10-18-2009 11:01 AM
Stripping to bare metal ,patch panels, and prep 74chevyflat Body - Exterior 17 07-16-2008 08:23 PM
Urethane 2x primer on bare metal Abby.Normal Body - Exterior 24 07-08-2007 08:23 PM
Sanded to bare metal...What's the best thing to cover again? Rocket1 Body - Exterior 7 09-09-2004 06:24 PM
jasco and bare metal. abe Body - Exterior 3 10-06-2003 11:02 AM
