1pc. oil pan gasket leak
I'm using the Milodon 1 pc. oil pan gasket on my SBC with a Milodon pan. It leaks at both front and rear seal areas. Can I use RTV on those rubber seals? I was planning on dropping the pan, cleaning it up, putting a bead of RTV in them and then bolting the pan back on. Will this work?
