Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1pc. oil pan gasket leak
Old 07-14-2010, 07:27 AM
sqzbox's Avatar
sqzbox sqzbox is offline
My pipes are my music
Are you telling us that your planning to re-use the same gasket?
Either way, let that sucker set up for a couple of days to get a good seal and look into your breathing system as excessive crank case pressure might be some of the problem such as bad PCV valve, or plugged up breather cap on the valve covers.
