1st drive with new 400sbc and powerglide trans - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-17-2013, 07:39 PM
Banned
okay so for my 1st drive of the 400 things seem a little weird. I have a powerglide and tci 24-2600 stall converter. the car didn't seem like it wanted 2 shift out of 1st for a very long time. I only averaged about 30mph the whole trip home. but being used 2 the 307 I could tell when it needed to shift. the car did shift out of 1st when I let off and got back in a few times. could the motor b looking for a certain rpm before it shifts into 2nd? I have a big 488/510 cam with 114 lsa. should I b worried about burning up the trans or something? the torque converter is fairly new.
Old 01-17-2013, 08:54 PM
vinniekq2's Avatar
post the stats on that cam
Old 01-17-2013, 09:41 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
do you have the throttle linkage for the powerglide hooked up?
That linkage affects shift timing.
The modulator on the powerglide affects line pressure
Old 01-17-2013, 10:12 PM
Banned
hyd flat tapp rpm range 3000-6500(rated350)
intake dur. 050 234/244
adv 292/302
I do believe its something with the throttle linkage. from what I see my dad left a spring hooked up to one of the valve cover bolts. I see a part where there loiks like the spring was supposed to go, but the spring is 2 big. think autozone will have wat I'm lookin 4?
Old 01-17-2013, 10:22 PM
Banned
ima post a pic in my album and tell me if I think I'm on the right track.
Old 01-19-2013, 10:41 PM
Banned
having driven it a little more to understand the motor.
I can see it goes to about 40 in 1st. then I can let off and hear it go into second. in second when I press the brakes it can drop down to about 20 or so before it shifts back into first.
I LOVE THE 400'S TORQUE. I can let completely off the gas in 2nd and the car drops to idle it sounds like and just chugs along. I chugged along one road for about close to 2 miles @ 36-38 mph.
I have seen a 17 mile highway trip from work without the gas guage barely movig so I'm happy about those potentials.
I'm very grateful 2 be the driver of this car and will do my best 2 respect it and its power.
NEXT BIG FOCUS is gonna b TRACTION and beefing up the powerglide.
Old 01-19-2013, 10:52 PM
vinniekq2's Avatar
best way to beef up the glide is to install a t400. no kick down linkage,move the x member back 2 inches,shorten and balance drive shaft,change yoke.
82 elcamino slips when maually put in 1st, 2nd, or drive but takes off fine from OD sanawa Transmission - Rearend 0 01-24-2012 02:36 PM
powerglide trans with no reverse byon49 Transmission - Rearend 9 08-03-2011 06:51 AM
2 speed powerglide trans 64r1 Transmission - Rearend 2 08-03-2007 10:29 AM
Front drive 3.8 Buick to rear drive trans Chopt 48 Engine 0 04-30-2006 02:43 PM
1st and reverse no drive or 2nd NIWROC Transmission - Rearend 4 12-22-2005 01:04 PM
