1st project - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-18-2005, 10:02 PM
1st project
I have a 78 malibu and I want to know will S10 arms and spindles bolt right up to my vechicle.
Old 04-18-2005, 11:58 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
not sure
I know the steering box and pitman arm are the same. I am not sure about the rest of the components.
Old 04-19-2005, 07:30 PM
broncoII88's Avatar
Do the right thing...
Why do you want to put truck parts on a car? The spindles are most likely too big to mount on the malibu!
Old 04-19-2005, 08:44 PM
1st project
I am trying to raise my car up so I am trying to go with some raised spindles that would bolt right up.
Old 04-19-2005, 08:49 PM
poncho62's Avatar
Wiki Edits: 5
Stiffer springs would do a better job and would be cheaper...............
Old 04-19-2005, 08:57 PM
1 st project
Well I already put 1500 coil springs in there but I need it much higher. I am try to stay away from a body lift kit.
Old 04-24-2005, 05:37 PM
bracketeer's Avatar
489 Lemans
contact weimer
The S10's also share the same front suspension parts and rear differential and brakes from the Monte Carlo,Malibu,(some) Camaro, Cutlass, Regal, Trans Am..etc, along with the steering column and various engine parts. The frames are boxed until you get back to the bed. They are basically a blank canvas for anyone ever wanting to customize one, there is about a billion parts made for them, everything on an S10 is inexpensive (you can buy new fenders for $30!) The are easy to find in any variation(lonbed,shortbed,ext cab, 2wd, 4wd) I bought 2 S10's when I started my project for less than $400. Sold the parts that I was not using(after keeping the better parts) and made about $600-$700. There are several companies that make street rod bodies to bolt directly to an S10 frame, so if you get tired of the stock sheetmetal, you can bolt on a Studebaker or (yes even) a Willy's. Several people use them for various other projects also. I know of one guy that is shortening an Ext.Cab frame to use under a '35 Ford Delivery.
Need anymore info?
Later,
WEIMER
Old 04-24-2005, 07:01 PM
1st project
Do you know of any good websites to go visit,to lift a S10. What type of brands to stay away from?
Old 04-26-2005, 07:29 PM
broncoII88's Avatar
What brands to stay away from...
Anything made in China!
New project? Before turning a wrench, get organized! Centerline Hotrodding Basics 71 03-10-2013 11:29 AM
New Site Feature: Project Journals Jon Hotrodders' Lounge 8 01-08-2005 10:10 AM
ATTN: Project of the Week Submitters Jon Hotrodders' Lounge 3 04-22-2004 12:04 AM
Thanks to Project of the Week submitters Jon Hotrodders' Lounge 0 12-06-2003 10:23 AM
1st project Sims1967 Engine 9 06-08-2002 07:28 AM
