1st project nees some advice - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-12-2006, 11:57 PM
I have my first hot rod project it is a 1953 chevy pickup 1/2 ton.
I Just bought a mustang II with aldan eagle coilovers and 2 inch drop spindles and 11 inch brakes. I am wanting to go with leaf springs in back do I need to have the same shock as up front or can I go with a different brand? I have heard coilovers in the back will ride kinda rough.
Also should I box in the frame? I am looking towards a LT1 or a LS1 fuel injected motor. any help would be appreciated thanks
Old 02-13-2006, 03:33 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Front and rear shocks can be the same brand..just need different valving for the front and rear..leafs in rear are fine..you may need to do some adjustments or changes in spring rate to get the car to handle and ride well..you won't know that til you drive it..we do need to know the front and rear axle weights so a informed EWAG can be made on spring rates..
OMT
Need advice for first project car JohnnyMiddlefinger Body - Exterior 13 01-01-2006 04:02 AM
The Car Music Project: garage band with instruments made from an old Honda hoodoo Hotrodders' Lounge 0 07-22-2005 12:08 AM
Recommended paint brand for 1st project? Gearhead forever Body - Exterior 24 07-09-2005 08:07 AM
Project planning 580Z Hotrodding Basics 5 04-27-2005 03:20 PM
1st project Sims1967 Engine 9 06-08-2002 07:28 AM
