1st and reverse no drive or 2nd - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-18-2005, 06:12 PM
Will drive in reverse and manual first but in drive or second it wants to go but don't. Any ideas? Thanks Rod
Old 12-18-2005, 06:44 PM
BOBCRMAN@aol.com's Avatar
Hold the car up against the screen and tell us---WHAT KIND OF FREEKIN CAR/TRANS YOU GOT????
Old 12-18-2005, 07:45 PM
Frmly sc*ot.
Maybe the overunning clutch [sprag] is slipping.
Old 12-18-2005, 10:20 PM
YOU DON'T HAVE TO BE SUCH A FRIKIN *****!!!!!!!! It's a TH350C in a 1986 GMC Sierra C-1500, 2WD, 305 4BBL, 2.73 Differential, No AC, PS, PB, White in color. The lockup is unhooked and so is the TCS (transmission controlled spark). P.S. I'm new here thanks for the friendly welcome.
Old 12-22-2005, 01:04 PM
sbchevfreak's Avatar
Licenced Automotive Technician
What he said.
BTW, I believe I answered this in your earlier thread. If the lo roller will not hold, the rear planetary gears will not be held, and you have no reaction member. In order for power to be transmitted, a drive member and a reaction(held) member are required. When you put it in M1, the lo-rev band applies and holds the rear planet carrier still, and you drive.
General reverse and 1st gear ?s in auto trans scot Transmission - Rearend 3 12-17-2005 10:09 AM
88 jimmy, 1st & 2nd only freddy2 Transmission - Rearend 3 10-18-2004 09:47 PM
th350 no 2nd gear mkolstad Transmission - Rearend 2 07-10-2003 08:56 AM
TH350 Reverse Problems TNEddie Transmission - Rearend 3 02-14-2003 06:27 PM
Where is 1st & 2nd? canine1566 Transmission - Rearend 1 09-25-2002 08:52 AM
