1st series '55 Chevy pickup - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-24-2008, 04:13 PM
I'd like to hear from someone that has modified their truck's frame to allow for power steering and disc brakes. What's involved in getting the required parts and doing what is needed for this project?
Thanks
Old 02-24-2008, 04:24 PM
1952_Chevy_Panel's Avatar
Money pit
We use camaro clips. Some people use nova, some mustang II, other volarie (sp). Depends on how much you want to spend really. We spend around $400-$600 by the time we use poly bushings, same blast it, primer it, paint it. New tie rods, centerlink, so on. The stuff adds up quick.
Old 02-24-2008, 04:25 PM
NEW INTERIORS's Avatar
Set no limit's on yourself
I just put a 70's Nova front frame clip,On a 58 Chevy truck,I have some pics in my album. The nova is 1-1/2'' narrower,than the camaro.
Old 02-24-2008, 04:49 PM
You mention "clips", I'm sorry but I'm unfamiliar with the term.
Old 02-24-2008, 05:02 PM
It is the frame out of a camaro or Nova. This is a Nova clip.
Old 02-24-2008, 05:36 PM
Would an auto dismantler be the best place to locate these clips? Would I have to purchase the used frame and cut it myself? Sorry, I'm new at this.
Old 02-24-2008, 05:47 PM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
I just read your intro. Since you are keeping the 235 hydro, you "could" just add P/S and a power brake booster to the stock drum brakes.
I've run power drums on my 63 suburban and hauled lots of weight. It's all a matter of your driving needs and skill level when it comes to doing a frame clip, or keeping it basic.
Either way will work.
Old 02-24-2008, 05:52 PM
F&J F&J is offline
And to answer your question on where & how...
That clip pic; if you notice the back tails and see holes there. The camaro & nova have a "sub frame"; not a full length frame, so you unbolt that subframe and bring it home. Then you need to cut the front off of your full frame and splice them together.
Yes a wrecking yard is the easy way to get one. Maybe more money that scrounging the papers and swaps for one.
Attention: Willing to trade a *********for 55 buick or 48-54 chevy... DeathByGreaser Hotrodders' Lounge 5 10-23-2009 08:49 PM
1st series 1955 Chevy P/U mikenelson Introduce Yourself 3 02-24-2008 06:30 PM
Chevy Oil Pickup Installation Question leejoy Engine 13 02-11-2008 02:17 PM
55 chevy truck - 2nd series 1stproject Introduce Yourself 1 12-05-2007 08:51 PM
55 chevy engine swap timrocket72 Engine 0 11-04-2003 09:33 PM
