You could fit 2.08 valves if you wanted to. Unless you are running nitrous or forced induction a 75% exhaust to intake flow ratio is optimum. Valve size doesn't change that by itself, but it can help.
Yes, you should put in 1.6 exhuast valves if you are putting in larger intake valves. In fact, if you could just do one, I would put in the bigger exhaust, ALWAYS. A stock head is so bad on exhaust flow anyway it really needs some help.
Yep, a lot of people never think about the exhaust valve, but a larger one will do more good than a larger intake, especially with a good blend job.
Troy __________________ If you don't make mistakes. your not doing anything. 69 ss rs full custom camaro 98 ISCA grandchampion 69 ss rs bb camaro wifes driver 66 Elcamino 350/all dz parts,ac,windows,loaded,my driver 69 ss chevelle bb conv.fresh frame off 26 T sedan street rod |
If the're 882 castings go with 2.02/1.65 have the head shaved down .020 and use a .028 head gasket. ported, exhaust ported and polished,gasket matched, clean up the short radius, and you'll toss an easy extra 50 h.p. or so. mike
dont forget to unshroud the intake valves as they will be close. |
