2.02 vs. 1.94 valves - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-06-2002, 04:25 PM
stfinney's Avatar
Post 2.02 vs. 1.94 valves
I really need to know this. What difference will there be between the two valve sizes in the TQ and HP department?? Is there even enough to worry about with 170cc runners?
Old 11-06-2002, 04:40 PM
BOBCRMAN@aol.com's Avatar
Post
the 1.94 valves in a stock chevy head will give the best hp.& torque below approx 5000 rpm better driveability, nore response. properly installed 2.02 valves with a relieved combustion chamber will give better hp above 5500, both are dependant on cam specs.
Old 11-06-2002, 04:44 PM
stfinney's Avatar
Post
I've heard people talk about relieved combustion chambers. What are they exactly??
Old 11-06-2002, 06:20 PM
johnsongrass1's Avatar
Race it, Don't rice it!
Post
When big valves are so close to the combustion chamber side wall the valves become "shrouded" or in other words, they are so close to the chamber side wall that air flow is diminished. Chamber relief, or cutting and rounding the area closest to the valve will give the added
room the air needs to flow around that part of the valve.
Old 11-06-2002, 06:44 PM
stfinney's Avatar
Post
I have a pair of 487X heads with 2.02 valves. They came that way. Would they already have the reliefs built-in?? What about valve reliefs on the piston?? Do most pistons have these??
It's for a 350 SB with I think stock pistons. I would think a 350 would handle a 2.02 valve with ease.
[ November 06, 2002: Message edited by: stfinney ]</p>
Old 11-06-2002, 07:15 PM
Post
487x heads only came with 1.72 or 1.94 valves if you have 2.02's someone put them in there, is the intake real close to the side if the chamber? or is there about 3/16 clearance.
Old 11-06-2002, 07:42 PM
stfinney's Avatar
Post
Every site I have looked at shows different, not to say your wrong. Here are a few:
<a href="http://www.chevytalk.com/tech/engine/SBC_Heads.html" target="_blank">www.chevytalk.com/tech/engine/SBC_Heads.html</a>
"487" 3973487, OR 3973487X. The regular casting was found on the 1971-1972 350 LT-1 engines, had 1.94/1.50" valves, 76CC combustion chambers, DO have accessory holes, intake port volume should be 161CC's, exhaust port volume should be 65CC's. The 487X had 2.02/1.60" valves.
<a href="http://www.chevellepages.com/numbers/SBlock-head_Numbers.htm" target="_blank">www.chevellepages.com/numbers/SBlock-head_Numbers.htm</a>
3973487, 1968 / 79, 350, 1.94 / 1.5 or 2.02 / 1.6
<a href="http://www.ammotorsports.com/chvheads.htm" target="_blank">www.ammotorsports.com/chvheads.htm</a>
3973487X, 75cc, 2.02 1.60, 1971-72, 350
Old 11-06-2002, 08:50 PM
Post
1.94 inch valves as apposed to 2.02 inch valves--humm really depends on the cam, if your cam is going to be less than .5inch lift stick with the 1.94's these will help your heads swirl better at low lift(after all-your valves are at lw lift twice in the cycle as apposed to max lift only happening once-so swirl is deffinatly a good thing).although a 2.02 inch valve wth 30degree seats will accomplish the same thingif you have a high lift cam then 2.02 is well worth the money spent to help out with high lift flow. or you could use the 2.02 inch valves and smooth out the short side if you deside to portand polish the heads and this will give you the of best worlds.
---just my opinion
P.S. dont know about this where your at but here its only about 50 bucks to have the head releaved for 2.02 inch valves
Old 11-07-2002, 09:49 AM
Post
In addition to the other great information on this subject I am submitting the following as described by a friend.
"All this means is that in this particular application that you need valve
reliefs in the piston so that the valves will clear the piston. Why? There
can be many reasons for the need of this, some contributing reasons can be
raised C.R., larger valves, change in valve timing (cam shaft), increase in
valve lift (cam or rocker arms). One or many of these things can cause the
need to have valve reliefs (i.e. cutouts on top of piston where the valve would
possible come in contact if it weren't cutout) on the piston."
Old 11-07-2002, 02:29 PM
stfinney's Avatar
Post
I have a Comp. Cams 4x4 Xtreme Energy cam with a duration of 250/258 and a lift of .432/.453 and a duration @ 50 of 206/214 which puts out alot of torque and a Brodix HP-1 Intake Manifold which is great for low end torque. I also have .500 lift Z28 springs with hardened retainers and 7 deg. keepers. With the engine making alot of torque, would the 2.02 valves hurt me that much? Do stock pistons with reliefs have enough of a relief to accommodate 2.02 valves? I guess that is my main question!! Thanks for all the info!!!!
Old 11-07-2002, 03:53 PM
Post
your stock pistons have plenty of clearance for 2.02 valves at the lift that your cam has. I checked your web listings and copied them, they are sure not gospel! lots of errors, if i can i will find an AERA listing which is used by all the machine shops . if there were 2.02 xheads i stand corrected, but i have never seen any in 35 years of rebuilding cylinder heads. neither has my employer. he showed me two sets in the warehouse and both were 1.94s. thanks bob
Old 11-07-2002, 04:16 PM
stfinney's Avatar
Post
I am not an expert on heads myself. Not even close!! LOL I was just going by what I have heard and saw, so, who knows, maybe your right! Anyway, I could use these heads without any problems then, right??
Old 11-07-2002, 04:24 PM
Post
YES
Old 11-07-2002, 04:27 PM
stfinney's Avatar
Post
Thanks a bunch! I feel a little better now. I didn't really want to have to buy another set of heads, if these would work fine. How much usually does it cost to have hardened valve seats installed?
Old 07-03-2005, 12:25 PM
Rpms
What is the redline for one of these 487x 1972 350 chevy engines? one of my friends with a MT said he got his to 6700, but i'm sketpical.
