-   -   2 1/2 Rams horns. (http://www.hotrodders.com/forum/2-1-2-rams-horns-142674.html)
49willard 07-28-2008 03:59 PM
2 1/2 Rams horns.
I had asked in another thread an did not receive a reply so I will try again. Are the 135 degree dump rams horns available in 2 1/2 inch discharge. I have a pair of 2" dump 135 degree dump and I understand that the straight dump ramshorns were on some corvettes in the 2 1/2 inch discharge. Anyone know!
busterwivell 07-28-2008 04:24 PM
I know they had 2 and a half inch rams horns, but can't remember if they were straight or angled (see age above). Not too long ago, you could still get them from the Chevy dealers (not cheaply, but you could get them). Not all the info you wanted, but a little bit.
Dave 39 07-28-2008 11:07 PM
I can't answer your question but in a flyer I just received from Speedway they have 2 1/2'' straight dump ramshorns with generator bracket for $60 each. At that price they must be made in China but Speedway usually stands behind their stuff. Dave 39
75gmck25 07-29-2008 06:28 AM
The straight dump rams horns are also available as a standard replacement part from Dorman. I think you can get them at any PartsAmerica.
Some GM dealers also still sell them (Gilbert Chevrolet used to sell them over the web), but I think they are old stock.
Link to the dorman manifold
http://www.midwayautosupply.com/m-11...fold-kits.aspx
Based on the pictures, the 2 1/2" are straight dump, while the smaller ones from the trucks are angled dump.
Bruce
MI2600 07-29-2008 07:44 AM
The 2 1/2" types were/are all straight dumps. The angled dumps were used on trucks and Chevy IIs.
49willard 08-06-2008 03:58 PM
Thanks for the reply. I thought that the 2 1/2" were all straight dumps. I need the angle dump to clear the Jaguar IFS rack and pinion on my 49 F-1. I currently have the 2 " angle dump fitted up but would go out in search of a 2 1/2" angle dump if such a manifold existed.
DoubleVision 08-06-2008 08:13 PM
Port the ones you have, they usually have plenty of meat in them to port. A carbide cutter does the trick nicely.
