2.2l Ecotec - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-12-2010, 06:08 PM
ss396si's Avatar
2.2l Ecotec
I'm just curious to know if somebody sells perfrormance parts for a 2004 chevy classic 2.2l ecotec.I'm thinking about throttle body, intake and pullys etc. Would PORTing out the intake and exhaust manifold be worth it????? This is just my little 4 cyl work car that i would like to modify. My real car (the 69 Chevlle) will be on the back burner due to my wifes pregnancy.
Old 08-13-2010, 03:10 PM
bigdog7373's Avatar
Of course it's fast
You could turn it into a ricer and put a body kit and fart cannon on it with some black steel rims. lol. But really, i wouldn't waste time trying to make a little 4 cylinder fast. Stick with the chevelle.
Old 08-13-2010, 03:24 PM
Overdriv's Avatar
How much money do you want to spend? How fast do you want to go?
Two questions that apply to all hot rod projects.
Consider this;
Engine Type: Inline 4-cylinder
Displacement: 2.16 Liters
Bore x Stroke: 89mm x 89 mm (destroked for high RPM operation) Valves/cylinder: 4
Balance Shafts: Removed for high RPM operation
Block: Aluminum (lost foam cast) with steel cylinder liners
Head: Aluminum (sand cast) with custom race porting
Crankshaft: 3.505 Billet Steel
Rods: Manley I-beam, 300M material
Pistons: JE aluminum with 22mm PPP Pins
Compression: 10.8:1
Camshafts: Comp Cams billet custom ground, with roller finger followers
Induction: Borg Warner S400 Turbocharger w/ air to water intercooler
Ignition: Capacitive discharge by MSD
Fuel Delivery: 3 injectors per cylinder with FAST XFI controller
Fuel: Methanol
Lubrication: Dry sump
Exhaust: 4 into 1, custom bent
Horsepower: 1450hp @ 9200rpm
Torque: 940 lb-ft @ 7700rpm
I think that would get the your little Cobalt noticed!!
Go here to read about this
Old 08-13-2010, 08:36 PM
LATECH's Avatar
HAHA we call them fart cans. I like the sound of FART CANNON hee hee.
It would make a cool dune bug or go cart...maybe a portable generator.
Yeah stick with the chevelle use the cavalier or cobalt whatever for parts running and groceries. After all the wife will need something to drive to walmart.You wouldnt park the chevelle down there now.... WOULD YOU!
Old 08-14-2010, 05:09 PM
ss396si's Avatar
I wouldnt park my Chevelle in Walmart, we dont even have a Wallmart out here. I was just interested in making my work car a bit faster. I will always stick with my Chevelle guys!
Old 08-14-2010, 07:37 PM
To get back to your original question, start with GM Performance Parts. They have LOTS of stuff for the Ecotec, some of it even emissions certified for your 2004.
Old 08-14-2010, 07:40 PM
LATECH's Avatar
sorry ss396 I guess i was having fun at your expense. My Bad. I like the ecotech 2.2 engine. They do pretty well. Dont know what you could do to get more power from your 2.2. I guess you could tweek the flash program add some timing and fuel . probably not much room to move tranny shift points around.( I assume it is an automatic). Smaller diameter tires would effectivley change the final drive gear ratio which might give you a little better off the line response so i guess there is a few things you could try. Have you tuned it up lately? How bout some injector cleaner and a new fuel filter. Fresh oxygen sensor? A little here a little there pretty soon you know....
Old 08-15-2010, 12:08 AM
454headache's Avatar
I'll take on any Ecotec with my Nova, my 1985 Nova that is,lol. 1.6 liters of American badged built by Toyota muscle.
Old 08-15-2010, 06:51 AM
Slap a modern turbo system on it, some cams, and some pistons. Total cost of about 4-5 grand and can easily hit 450 hp (though lower power numbers will have faster spool). That'll burn the front tires right off.
Old 08-16-2010, 12:37 PM
ss396si's Avatar
So far I put a fresh set of brakes and hardware all around, plus a K&N air filter. Next i'll change the belt then check the spark plugs and wires. I was just curious to know whats out there performance wise. I plan on keeping it for a few more years. My next vehicle will hopefully be the Colorado with the 5.3L vortec. Now do you guys know what Is out there for this truck??
Old 08-16-2010, 02:03 PM
bigdog7373's Avatar
Of course it's fast
I don't remember a colorado being offered with a v8 unless the new ones have it. The largest engine was alway a 5 cylinder. As for the 2.2, how bout some cams? Get a header for it (<boy did that feel weird to say! only one header! haha) and put a better exhaust system, but please a quiet one. A larger throttle body would give it some power too.
Old 08-16-2010, 05:05 PM
ss396si's Avatar
The colorado is offered with a V8 this year. A bigger throttle body sounds great, I'm trying to find an interchangable part.
Old 08-16-2010, 05:20 PM
bigdog7373's Avatar
Of course it's fast
The colorado is offered with a V8 this year..
It's about time!
Old 08-16-2010, 07:21 PM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
It's about time!
Fuel mileage rating is the same as a Silverado . What ?
Old 08-16-2010, 08:40 PM
bigdog7373's Avatar
Of course it's fast
it better be fast!
ecotec 2.2L swap into datsun 280z? rreruption Engine 16 12-15-2014 06:46 AM
need tips on locating a 2.2L saturn engine... fast68 Engine 9 03-26-2010 01:49 PM
2001 S-10 2.2l loses power sometimes need help RodFather Engine 2 08-03-2008 12:03 PM
Ecotec adaptor to T5 transmission johnod32vicky Hotrodding Basics 3 11-06-2007 09:17 PM
2.2l head question 74huggerorange Engine 2 04-11-2003 07:04 PM
