2.3L 4 cyclinder 1988 mustang motor... - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-03-2007, 02:56 PM
Why is this engine the biggest Pos ford ever made??.....
I changed the head gasket and put it all back together exactly how i took it off and now...it doesn't run.. IT ran before we took it apart..and now it will crank up but has no power at all it barely moves in drive or reverse. Help plz.. A neighbor of mine has recently redone one of his mustangs and i thought he was just being wasteful when he threw out his 4cyclinder motor on the ground....now im beginnings to wonder if its not a smart thing to do.
Old 06-03-2007, 03:08 PM
are you sure you have the timing belt put back on correctly???????
Old 06-03-2007, 04:31 PM
Wiki Edits: 31
yeah. the OHC 2.3's are really good engines. better if there the Turbo versions, but there all good. check the cam timing, it's probably retarded.
mustang motor mounts??? shagginwagonvic Engine 3 01-19-2004 08:30 AM
Are Mustang II Crossmembers Safe? Jon Suspension - Brakes - Steering 14 10-17-2003 12:43 PM
ranger w/ a 2.3 mustang motor redflameryder Engine 12 08-26-2003 10:47 AM
Mustang LX 2.3L Worth Working On? Locutus Engine 4 08-07-2003 10:26 PM
Can I put a AODE in a 1988 Mustang GT? kodd Transmission - Rearend 2 10-15-2002 01:22 PM
