2-4 band? Or servo? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-19-2013, 02:46 PM
Beerman28
2-4 band? Or servo?
4l60e no 2nd or 4th, but i DO have reverse. What test can i do to determine if its the band or the servo?
Old 11-23-2013, 02:54 PM
Think we need a little more info. How many miles, any previous problems. Have you checked fluid, does it smell burnt or look different? You need to put a pressure gauge on the tranny and get some readings.
Old 11-23-2013, 05:05 PM
Beerman28
Its only a yr since rebuild. Maybe 15k?
Wont shift into 2 or 4th manually or auto. I just need to know how to test the band and servo seperately to determine which one it is.
Old 11-23-2013, 05:25 PM
Last journal entry: Still running strong
2-4 servo assembly - 2th apply piston seal missing, cut or damaged. I just happened to have a ATSG manual in my lap.
Old 11-23-2013, 06:09 PM
Beerman28
2 apply piston location? Is that part of the servo?
Old 11-25-2013, 10:08 AM
Beerman28
Pulled the trans yesterday. Tore it apart to find a broken band. Replaced the band and a few other things while it was on the bench. Got it back in last night, and now i have all 4 gears again!... Thanks for all the help guys
yet another 2-4 servo ? t00lmanii Transmission - Rearend 1 10-27-2009 12:12 PM
Wide band or narrow band A/F...? staleg Engine 6 08-12-2008 02:10 PM
700R4 Did I "miss" the band when reinstalling the servo? Bayley Transmission - Rearend 12 05-13-2006 01:07 AM
best band 2003 Audioslave. best band 2004 Velvet Revolver bullheimer Hotrodders' Lounge 21 02-02-2005 09:43 PM
What does the Servo do? KeithB123 Transmission - Rearend 10 11-10-2004 03:14 PM
