2 or 4 port master cylinder? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-19-2012, 08:32 PM
Hey everyone,
I have a 58 chevy PU with a volare front clip. So its disc/drum with the MC/ booster mounted under the floor. I have been having some problems with the brakes so I bought a complete booster/MC/petal kit.
The problem is the MC thats on the truck is a 2 port and the one with the kit is a 4 port. So my question is can I just block off the 2 unused ports? Should I buy a 2 Port MC or should the brakes be re plumbed for a 4 port MC?
Thanks for any advice I probably know less about brakes than I do any other part of an automobile.
Old 08-19-2012, 10:55 PM
RWENUTS's Avatar
If by 4 port you mean 2 on one side and 2 on the other just plug off the side you don't use. Use a proportinal valve with 2# front and 10# residual check valves.
which port is front and rear on the master cylinder? Augusto Suspension - Brakes - Steering 4 05-09-2012 12:30 PM
Cylinder head port filling Diskovod Engine 10 10-01-2011 03:22 PM
What master cylinder? Jzarczyn Suspension - Brakes - Steering 2 12-11-2005 11:23 AM
cylinder heads; port and valve job toddtheodd Engine 1 01-05-2004 09:07 PM
Do you need to bleed both sides of a 4 port master cylinder brian400ex Suspension - Brakes - Steering 2 03-23-2003 10:30 PM
