2.41 10 bolt Posi-Traction Rear end - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-02-2003, 12:17 AM
ecrusch1987's Avatar
Question 2.41 10 bolt Posi-Traction Rear end
I have a 1978 Chevy. El Camino with a Posi-Traction rear end. Reciently 3 of the 4 spider gears have been destroyed. 2 were shattered, and one is stripped. I was wondering why this could have happened and when i replace these parts am I going to have to realign the rear end? I am only 16 years old so i dont know much but I have people around that are going to help me with this "project". I am also wondering if I am going to have to order a spider gear assembly with the same gear ratio or if that doesn't matter with them, I know that the car currently has a 2.41 ratio in it and a three speed automatic tranny hooked up to a 350 ci. engine.
Old 11-02-2003, 12:21 PM
Well the usually reasons for spider gear failure are getting suck in the snow and spinning the tires or shock loads or peg legged burn outs. Now with a functioning posi unit being stuck or doing burn outs shouldn't hurt the spider gears as the posi is stopping them from turning hence stopping their wear. May guess is that the clutches are worn out and allowing it to function like an open rear end. My advice is you change the spider gears and the clutch packs and that should get you back in business but just check that any pieces from the spider gears didn't damage the carrier or go trough the ring and pinion.
Old 11-02-2003, 02:30 PM
Bumpstick's Avatar
Hammer and a torch
Dont waste any more time or money with a factory posi setup... Spend the little extra $$$ and get an Eaton posi-unit and thank me later... I too tried the factory route and finaly took the plunge and sure wont look back now... Also after you finaly wear out the clutches it can be rebuilt and any other parts are easy to aquire also...
Old 11-02-2003, 02:35 PM
Just so you know it isn't the factory rear end. It was replaced about 4 or 5 years ago with a performance one. Could it also be that the car has about 400 Horse Power.
Old 11-02-2003, 03:17 PM
Yes that is some good advice the aftermarket eaton posi's are much stronger than the factory ones
Old 11-02-2003, 03:35 PM
I looked into a new Eaton Posi rear end, unfortinatly I dont have that kind of budget thanks for recomending though, i'll start to save up for it...
