2.41 gears to 3.73? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-02-2007, 10:59 PM
2.41 gears to 3.73?
i'm wondering if i can change my 2.41 (10 bolt) rear end gears to 3.73's ive had enough of not being able to squak my tires off the line and if i can can someone tell what it takes, thanks and this is a 10 bolt rear end for a chevy
Old 08-02-2007, 11:07 PM
DHMag's Avatar
you shouldnt have a problem breaking them loose with the 2.41s. i can roast tires with my 2.29s in a full weight 1979 Malibu with a 305.
Old 08-02-2007, 11:18 PM
MI2600's Avatar
Member# 3287
You can change the gears, but you'll need a "3" series pig.
Since you ask the question, I think you'd better have someone else do it. You don't want a "howling success" story.
The 3.73 gears will let you spin tires...while you watch your gas gauge go down.
Old 08-03-2007, 11:27 AM
I'd keep the 2.41 and go after more torque from the engine.
My 462 (4.21 stroke) loves its 2.56 posi!
Not to sound like a smart ***** but why do want to lay rubber anyhow? Wouldn't you rather go like hell!
Old 08-03-2007, 01:37 PM
Southern's Avatar
Maybe it's a red-light to red-light deal.
454 XE268 2.41 gears Will It Work? ylwdog1 Engine 10 06-02-2007 02:54 PM
8.2 3.73 Gears for a 1968 FireBird? stevo68 Transmission - Rearend 2 11-27-2005 07:15 AM
th700-r4 & 3.73 gears?? Brian Morency Transmission - Rearend 8 09-18-2004 08:10 AM
do i need a carrier for 3.73 gears? camaro_85 Engine 1 07-29-2004 11:23 PM
3.73 gears good or bad? cragars Transmission - Rearend 6 03-09-2004 01:54 AM
