2:41 gears in a 81 Firebird - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-22-2005, 09:06 AM
New Member
My 1981 Firebird has 2:41 gears in it, how much of a dog to you think these gears are makeing it? As of now it is at the shop haveing a new eaton posi track and some 3:73 gears put in. It has a chevy 350 with a comp cam dur 222 with a lift of 447, speed pro flat top pistons 9:5 comp, With a edlebrock preformer intake, edlebrock 650 preformer carb, flow tech headers, all has been balanced, How much of a diffrence to you think I will see with the new gears?
Old 03-22-2005, 10:32 AM
Ghetto Jet's Avatar
pic of my Cobra should be here
Last journal entry: Lets Get Started With the Improvements
I would tell you but I don't want to ruin the surprise.
Old 03-22-2005, 10:42 AM
STUPID is as STUPID does...
What he said...
Old 03-22-2005, 12:39 PM
hmmm... hehehe you will find out soon eough
Old 03-22-2005, 12:45 PM
New Member
Your putting a smile on my face
Old 03-22-2005, 04:55 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
NAH, they are just yanking your chain.
If they do the complete job and also change the speedometer gears, you "might" like the change.
Just be careful you don't snap your neck when you mash the GO pedal.
You might also look into having to change the whole axle later on if you decide to do too many neck snappers to show off to your friends, the 7.5 inch axle isn't known for it's strength.
Old 03-22-2005, 05:37 PM
Ghetto Jet's Avatar
I don't think they went to the 7.5" rear until 82 when they went to the third gen. body style. I could be wrong though.
Old 03-22-2005, 07:04 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
No, you're right 1982 was the first year for the 7.5 in the F-body, his 81 should still have the 8.5 inch.
Old 03-22-2005, 07:37 PM
New Member
WOW++++WOW Got it back from the shop, Made a world of difference. Thanks for the replys!!!!!!!!!!!!!!!!!
Buick 231 ci in 81 firebird camaroguy_1967 Engine 29 08-12-2004 11:48 AM
3.73 gears good or bad? cragars Transmission - Rearend 6 03-09-2004 12:54 AM
81 elcamino engine swap freeryde13 Engine 1 09-26-2003 03:27 PM
how to change gears.... jackflash Transmission - Rearend 4 04-10-2003 03:47 PM
Changing rear end gears... chevyelc81 Transmission - Rearend 1 07-23-2002 07:52 PM
