2.5 chrysler - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-27-2008, 08:54 PM
swvalcon's Avatar
Last journal entry: rust on lt body shell
2.5 chrysler
any chrysler tecs on here? I've got a 98 sebering with a 2.5 v6 it sends up a code p300. miss fire I've replaced plugs, plug wires, cap & rotor,It still miss firers at idle and up to 2000rpm then seems to run fine. When you frist take of from a light it falls on its face big time for a bit then seems to clear up and go.At 70 mph it runs along just fine maybe a little low on power but no noticeable miss. ever run into this?
Old 11-27-2008, 09:37 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
What weight oil are you running?
IIRC it should use 5W30 oil. A thicker oil on start up will keep the lifters pumped up while cold.
My next step would be to check fuel pressure, and volume.
It could also be a false reading O'2 Senor, or dirty Mass Air Flow Sensor.
Old 11-28-2008, 06:44 AM
swvalcon's Avatar
my brothers scan tool shows o2 and mas air are fine. would a vacuum leak at intake cause this?
Old 11-28-2008, 07:56 AM
My 2 cents worth
Wiki Edits: 3
Yes it can, so can an exhaust leak prior to the O'2 sensor.
Old 11-28-2008, 11:23 AM
sbchevfreak's Avatar
Licenced Automotive Technician
These 2.5 v6 mitsu motors were known for distributors causing missfires and no starts, as well. IIRC from my time with Chrysler, they are a b1tch to change.
fiero 2.5 to 2.5 swap tkas4x4 Engine 27 06-28-2011 05:07 PM
98 chrysler 2.5 v/6 swvalcon Hotrodders' Lounge 3 12-06-2006 11:41 AM
tail pipe expansion 2.25 to 2.5 spinn Engine 1 10-29-2004 11:58 AM
2004 Chrysler ME Four-Twelve Supercar fourbyfourblazer Hotrodders' Lounge 6 10-08-2004 09:23 AM
What is wrong with a chrysler 68newport383 Body - Exterior 23 02-11-2003 04:35 AM
