2 of 5 gauges not working - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-05-2009, 06:01 PM
My fuel gauge stays on full never moves, temp gauge doesnt move at all,speedo and volt and oil gauge works fine.All gauges are electric, I checked the fuse, looks good. I didnt wire this car its got an EZ wire system and the guy that did the wiring did a nice job everything looks neat and all so If anyone has some ideas Im all ears, Thanks,
Old 11-05-2009, 07:19 PM
poncho62's Avatar
Wiki Edits: 5
I would check the grounds to the dash. Those gauges may not be grounded properly
Ontario Rodders
Old 11-06-2009, 08:43 PM
Ground
Ok I'll take a look at that, thanks
Old 11-07-2009, 07:35 AM
You didn't mention what vehicle. The 60's Fords used a 5 volt instrument panel voltage regulator for the temp and fuel gauge. When it goes bad your gauges will not work.
Bruce
Old 11-07-2009, 08:12 AM
Type of car
Sorry Bruce, My car is a 34 chevy streetrod, the electrical system has been updated to a 12 v and the gauges are Classics from American. That is interesting about the fords,I didnt know that, thanks,
Old 11-07-2009, 12:22 PM
See my post on this thread:
fuel gauge reads full
hope that helps.
Old 11-07-2009, 07:30 PM
Matching sender to gauge
Wow that's something,I wounder if I should just find a new sending unit that is matched with a new gauge, I wanted to replace the gauges with stewart warner ones but i'll try running a ground wire to the dash like you did and see what happens, anyway thnks your info gives me something to work with,
Old 12-02-2009, 08:41 PM
I had a similar frustrating problem with my Classic gauges on a new install. Classic has a great tech line. I could not figure it out since I wired the car and have done it a lot of times.
Turned out to be a bad ground. I re-did starter, gauges and charging system with star washers and problem solved.
Custom gauges in 70 chevelle lumberjacknooj Interior 5 05-22-2006 10:17 PM
Elec vs Mech gauges 2 Fn LoW Electrical 4 05-01-2005 04:20 PM
digital gauges mmartin1872 Electrical 6 01-06-2005 11:58 AM
gauges fordred1 Introduce Yourself 0 09-02-2004 11:59 PM
digital dash gauges joe48066 Introduce Yourself 2 08-26-2004 09:18 PM
