2.56:1 posi rear end? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-18-2007, 08:12 PM
HI
I have a 2.56 posi rear end in my 76 chevy, can I change the gear (pinion and ring) for a 3:70, keeping my original positrack?
Or I have to change it for and other?
Old 11-18-2007, 08:17 PM
Hippie's Avatar
Last journal entry: HEI comparison.
If your differential is an 8.5" 10 bolt you'll have to use a ring gear spacer or thick ring gear. The 2.73 and lower carriers ( "lower" as in 3.08, 3.42, etc. ) don't need the spacer or thicker gear.
Rear end swap required & I'm cunfussed datsun dale Transmission - Rearend 8 12-17-2008 10:03 AM
84 Z28 Rear End TO Posi Traction Conversion x711 Transmission - Rearend 2 08-07-2006 08:51 PM
'79 seville Rear end Posi??? MrChevyDC3 Transmission - Rearend 10 12-28-2004 11:11 PM
75 dodge half ton posi rear end 81elcamino Transmission - Rearend 0 10-26-2003 03:33 PM
anyone running 700r4 with 3.55or 3.77 rear end? 37 chevy Transmission - Rearend 7 01-06-2003 07:34 AM
