2.57 to 3.08 rear end gear caprice - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-17-2013, 05:33 AM
I have a 1980 chevrolet caprice saloon 305 and TH 350
I bougt some uppgrades for more touque (i hope)
The engine is going to have an elgin 923 cam and edelbrock performe 2101 intake and single 2,5" exhaust with open mufflers and 4bb rodchester.
The question is that i think i have a 2.57 gearing and a friend of mine have a 3.08 he dont use, and i am wondering if this is going to be better.?
High rpm cruice issues?
Fuel economy is not an issue...
Sorry about bad english
Old 11-17-2013, 07:19 AM
delawarebill's Avatar
gears
i don't think moving up that much is an issue.. but go to summit and look up "ring and pinion gears' just below any gearing there is a calculator. now u've got the measure the OD of the tires for this. click on what answer u want and fill in the other 3 blanks and hit cal.
Old 11-17-2013, 07:45 AM
Thanks... i saw about 350 rpm higher at 55mph
Old 11-17-2013, 08:09 AM
big gear head's Avatar
High Performance Rear Ends
The 3.08 will still be fine on the highway. You will notice a little better performance from the change. I'm assuming that you are talking about changing the whole rear end. There is a lot involved in change the gears, but not in just swapping a complete rear end.
Old 11-17-2013, 08:29 AM
If you change the gears, I'd recommend you get the kit with the new bearings, seals and ect. . Get someone who knows how to do it. Its not just changing parts.
there is no problem in using, used parts if they're good ones. Just don't go cheep without replacing bearings and such, because i'm guessing there is a lot of miles on that chevy.
Old 11-17-2013, 10:20 AM
Thanks alot for the info.
i have help from a spesialist and im going to bye a bearing kit
Old 11-17-2013, 12:01 PM
Setting the pinion depth on used gears is very tricky. The contact pattern is very hard or impossible to read.
This question hans.t been asked yet, but are the gears from the same rear end as what you have in your car? If you have the 8.5 10 bolt then you must use gears from a 8.5 10 bolt. Also, your 2.56 gears will be on a 2 series differential. If you have the 8.5 then you will have to get a 3 series differential for the 3.08 gears to fit. If you have the 7.5 rear end then the 2.56 and 3.08 gears both use the 2 series differential. Like I said before, there is a lot to a gear swap.
Be sure to get a high quality installation kit. The cheaper kits like Ratech are junk. I don't know where you are, but getting a good kit might be a little more difficult if you are not in the US.
Old 11-17-2013, 01:45 PM
I have a the original rear axle on the car (caprice 1980) and from what i have learned it is a 8.5 10 bolt.
The 3.08 parts are from a 1970-80 gm axle also a 8.5 10 bolt
I have only done this once before in my chevrolet camao, when i changed from 3.08 to 3.73 this was a 7.5 (richmond gear) 10 bolt axle from a 1996 camro that i used in a 1987 camaro
Then i was running a 700R4 trans so the rpm on the highway was ok...but this time i have the TH350 so i dont want to go as far as 3.73
I am from Norway and the are som good companies here thas spesialises in american car parts, i also shop from Jegs and Summitracing
Thanks again for helpful information
Old 11-17-2013, 01:51 PM
So with the 8.5 rear end you will be needing a 3 series differential to go with those gears.
Summit and Jeg's installation kits are not very good, not any of them. If you can get a Yukon kit from someone local it will be a much better kit.
1987 Caprice rear end 87box Transmission - Rearend 8 11-15-2012 08:50 PM
1990 caprice with rear end upgrade questions cudablack2004 Transmission - Rearend 2 11-14-2011 07:13 PM
87 caprice Rear end swap with later unit? erbysandman1 Transmission - Rearend 1 04-06-2008 11:48 AM
95 caprice rear end swap? molotov 350 Transmission - Rearend 2 04-08-2007 02:04 AM
'91 Caprice 9C1 rear end noise Sandflea427SS Transmission - Rearend 3 02-21-2007 05:55 PM
