2.8 multi port - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-05-2007, 07:50 PM
chevrolet327's Avatar
second place is the first losr
Last journal entry: old stlyle holley polished valve cover
2.8 multi port
can i bolt a 2.8 multi port to a s-10 2.8 automatic transmission?
Old 09-05-2007, 10:24 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Last journal entry: 1999-2001: Getting it on the road
Wiki Edits: 16
Nope, FWD to FWD only, RWD to RWD only. The blocks are different.
Old 09-06-2007, 10:38 AM
is it the same bolt patern
Old 09-06-2007, 11:45 AM
curtis73's Avatar
Wiki Edits: 16
Only if you have a multi port from a camaro or other RWD car. www.60degreev6.com is the ultimate source for this kind of stuff.
Old 09-06-2007, 03:04 PM
The answer to your question, is Yes.... Any 2.8 Chevy engine, and I don't care what it came out of, will bolt to a 2.8 S-10 transmission. Same goes for the 3.1 and 3.4 motors that are the 2.8s big brothers. They all have the same bell housing bolt patterns.
You may run into mount problems, or the intake pointing the wrong direction, or even the starter being on the wrong side of the block if you try to put a front drive motor in an S-10.
If your doing a custom swap, most of the differences won't matter anyway. Dan
Old 09-06-2007, 05:06 PM
thank you very much ohio-dan i know the intake and starter are wrong i just want to put it in a suzuki samurai on off road only
Old 09-06-2007, 07:11 PM
The front drive MPFI engine would have the intake opening facing to the rear.... The hot setup would be to cut a hole in the fire wall, run a piece of flexible tubing in, and mount a canister type air filter inside the cab. This would greatly reduce the chance of the motor ingesting water or mud in extreme off road conditions. Same goes with the distributorless ignitions. The coil pack can be mounted securely inside away from heat and moisture....Dan
Old 09-06-2007, 09:40 PM
thank for the help dan
Port volume baddbob Engine 5 02-25-2007 01:45 PM
head flow velocity and port size 71javelin Engine 40 04-22-2006 12:32 PM
Timing Port Dilemma copndoc3 Electrical 1 01-22-2006 09:44 PM
Where is manifold vacuum port on Quadrajet 4mv? dr-data Engine 10 12-13-2005 04:41 PM
Timed Vac Port or Manifold Vac Port Sweet-34 Electrical 14 04-27-2004 04:35 AM
